IVE GOT A 306 2.0 HDI D-TURBO, ITS SWEET AS A NUT ON IDLE WITH NO NOISE BUT AS SOON AS I THROTTLE IT IT MAKES A WHINE, IT SEEMS LIKE ITS FROM BEHIND THE BLOCK SO LED ME TO THINK TURBO BUT ITS REALLY LOUD, STILL DRIVES PERFECT TOO AND TURBO STILL BOOSTS PERFECT, NO SMOKE EITHER:/, ANY SUGGESTIONS ON CAUSE OF THE WHINING NOISE? PLEASE IM IN DESPERATE NEED OF GETTING TO THE SOLUTION
PLEASE HELP.. ENGINE WHINE
09-06-2013, 11:26 PM
No need to put all in caps and you need to use full stops to make it make more sense lol
Buttt How loud is it? It could very well be the turbo on the way out. However some people do get worried when they can hear the turbo working lol never quite figured that one out haha
10-06-2013, 05:33 PM
it doesnt happen when the engine idles, its only there when you get to around 1500+ rpm. its really loud, just had another listen and sounds like fuel pump, does that sound possible?
10-06-2013, 05:58 PM
ITS MOST LIKELY THE TURBO FROM WHAT YOU'VE SAID.
10-06-2013, 06:01 PM
if it comes from the back of the block and starts at 1500rpm I'd definitely say turbo
idk about fuel pumps because the lift pump would make sounds in the tank and I guess when the hp pump makes noises it's so dead that your car won't run right
10-06-2013, 10:03 PM
have you ever heard of a noisy tensioner? ive spoke to a mechanic who said possibly tensioner or water pump because it sounds like a bearing whine, im going to remove the fan belt and run it without that tomorrow and see how it goes
11-06-2013, 02:58 PM
yeah try that one, could be the noise
15-06-2013, 01:03 PM
problem solved! anyone come across this fault in the future then its your idle pulley thats bolted to the bottom mount of the alternator
15-06-2013, 02:35 PM
Na just an idler pulley that was seriously worn, new part from gates was 25 quid
