11-06-2013, 08:51 PM
Bit of a odd one would it be any point in port an polishing the head on a hdi to as I got it off would it make any diff at all ?
port an polish
11-06-2013, 09:02 PM
11-06-2013, 09:03 PM
(This post was last modified: 11-06-2013, 09:03 PM by cwspellowe.)
(11-06-2013, 09:00 PM)Anton Wrote: You running 200bhp? You say it like you aren't? (11-06-2013, 09:02 PM)Jimbo Wrote:(11-06-2013, 09:00 PM)Anton Wrote: You running 200bhp? It WOULD make an improvement.. IF it was a restriction. Unless its a bastardly hard tune it's not really necessary.
11-06-2013, 09:06 PM
Should check post number before being funny. No i'm not Chris, not yet
Peugeot 206 GTI HDI
Volvo V50 2.0d Volvo XC90 D5
11-06-2013, 10:42 PM
I hear a bag of sand down the inlet will do it nice and cheap
12-06-2013, 01:25 AM
It'll slow down your air velocity in the port which could cause poor running at low engine speeds as it wont give as good a swirl in the piston bowl which in turn gives good fuel mixing and combustion.
There is however quite a bit that can come off the ports. Shame the valves are too close to eachother to be able to fit bigger ones. I've had a HDi head professionalaly ported I'll post pics but theres far better things to spend money on.
12-06-2013, 07:05 AM
Ok then ill spend cash on geting a better turbo if its going to slow it down then there is no point in doing it
12-06-2013, 07:18 AM
There are some good tuning guides on this site, I'd stick to the 'normal' stage 1 route rather than trying all the expensive things first!
EGR valve De cat Back box Remap Etc etc...
12-06-2013, 07:20 AM
all the above as said is almost cost free if you do it yourself...then remap is low cost effective, then FMIC
you can get a lot from a hdi without touching the turbo and head Wishes for more power...
12-06-2013, 08:16 AM
Just done stage1 just picked up a pipe bender to make hard boost pipes for the fmic plus going 2 make 2 half inch exhust do you need a back box on a diesel
12-06-2013, 08:21 AM
No you dont. Get rid of the back box and CAT . Need to leave the mid box for legal/MOT reasons
12-06-2013, 04:09 PM
You do need a box in the exhaust and at the back would be the better place to have it but the mid box is straight through and the back box is baffled so youll get a better increase by removing the back box compared to removing the mid box.
12-06-2013, 09:55 PM
Bugger then better get the mid box back then
12-06-2013, 11:23 PM
Unless you're north of the 200hp mark, it's going to be vastly fruitless, especially on a standard turbo...
There's a strong likelihood of rather than improving things, simply making it much worse. Unless you know whoever is doing it actually KNOWS their shit about DI Diesel engines, I wouldn't bother taking it anywhere... I don't know of anyone in the UK who I would take a DI Diesel head to who I would trust to improve performance...
13-06-2013, 07:34 AM
I'll scrap the port an polish plant then thanks fothe infor
13-06-2013, 07:41 AM
You can just use any old box thats been gutted for a back box, just needs hangars in the right places. Something of the same design as an hdi midbox would be ideal, but wont make much difference really.
13-06-2013, 12:26 PM
(13-06-2013, 07:41 AM)Poodle Wrote: You can just use any old box thats been gutted for a back box, just needs hangars in the right places. Something of the same design as an hdi midbox would be ideal, but wont make much difference really. Not true, on a stage 2 car the difference is the best part of 10bhp
13-06-2013, 12:57 PM
Exhausts IMHO are one of the biggest restrictions on HDis...
Not just the pipe either, everything back to the manifold. The elbow looks like it was designed by Stevie Wonder whilst having a bare mad trip on LSD...
So wot best then no box then looking to move on to stage 2 soon
13-06-2013, 01:01 PM
No boxes will get you pulled eventually, the "slappy" noise from the exhaust is so blatantly obvious of an exhaust with little to no silencing whatsoever...
Get a pipe made from 2.25 or 2.5" with one box at the back to take off the harshness... IMO Don't bother with the stock parts, the bends are so restrictive... Near enough all the stage 2s I've seen with decent exhausts have made more power than the ones using stock parts.
13-06-2013, 01:03 PM
^^ As Ruan says the standard exhaust is pretty restrictive and pattern replacements are worse.
ideally you want a 2.25" or 2.5" system with a single straight through box at the back.
13-06-2013, 01:22 PM
Awww right ill re make my exhaust then out of 2.5 pipe then in to a back box any sort of back box best the best 2 use?
13-06-2013, 07:47 PM
any back box with a straight through design will be fine.
15-06-2013, 09:04 AM
10bhp difference between a straight-through box and a straight through box with some perforated pipe in it?!? Impressive, i'll have to experiment with that.
The bends are fine on stock pipes, good and proper mandrel-bent stuff, it's the cheap pattern parts that are the issue. That said you'll be bloody lucky to find an original pipe or even decent after-market replacement on one of these lol.
15-06-2013, 09:34 AM
