Threads: 28
Hi guys, I'm going to be making my own cage soon and wondered which way is best to do it? I've seen some people go straight down to the boot floor (on to a plate) from the hoop. I've also seen some which go down onto the rear arches (also on to a plate). My rear arches are solid by the way before anyone asks
Just want to know what people prefer/recommended before I build it.
Cheers
Dan
Threads: 55
17
Car Model/Spec: 406 V6
Onto the beam mounts with mine.
Although, I do wonder if someone having to ask this should be DIY'ing a cage.....:/
Threads: 150
14
Car Model/Spec: 306 HDI
How much does a cage fitted usually cost?
306 HDI, soon to be XUD
Threads: 119
15
Car Model/Spec: Ph1 Diablo DT
(22-05-2013, 08:25 PM)Rippthrough Wrote: Onto the beam mounts with mine.
Agreed!
www.prestige-auto-care.co.uk
Threads: 136
(22-05-2013, 08:39 PM)declantg Wrote: How much does a cage fitted usually cost?
Not too sure, but I do know it costs a lot to have on your insurance each year!
Threads: 150
14
Seriously??? Even though its safety??
Threads: 61
11
My cages bolts in at the arches,I love it they as you can do a handy trick if you have 4 wheels you can put them side by side between the arches.its a perfect fit, snug as a bug
Threads: 119
15
All depends what sort of cage you want there's a few on eBay stating there 10 point cages etc and there actually not. Also people assume bolt in cages just bolt into a car they don't realise you need to have mounting points welded in or strengthened I'm sure ripp will show some of the work he has done
Threads: 61
11
22-05-2013, 10:13 PM
(This post was last modified: 22-05-2013, 10:15 PM by 7057sam.)
(22-05-2013, 10:07 PM)Ben Wrote: (22-05-2013, 08:39 PM)declantg Wrote: How much does a cage fitted usually cost?
Omp base model is £450-500 ish.mine is a safely devices 6 point with door bars and 'X' in the rear, which new are around the £600 mark.
I personally love the look and feeling of the extra security.after seeing a rolled 306 I neded one
If anyone wants any pictures im happy to help
Dec you going becaucetrackcar  306's feel so much better stripped
Threads: 55
17
23-05-2013, 12:08 AM
(This post was last modified: 23-05-2013, 12:08 AM by Rippthrough.)
(22-05-2013, 10:08 PM)declantg Wrote: Seriously??? Even though its safety??
Yep, a lot of firms won't even insure you for a car with a cage until you're over 25, as they know it's more of a serious track-car. Mine wouldn't, even on a 1.4, which is why I have bolt in errr, 'strut braces' across the doors and the same for a bolt in rear cross  )
Plus, if you're dumb enough to have a cage and rear seats, small accidents can turn into a couple of brain damaged passengers...which is expensive.
Threads: 34
My insurance cost nothing extra for a cage but yes alot don't like them and will even refuse insurance and tbh I'd imagine they would be as hard if not harder on a home made cage as they've no way of knowing without having a report etc if its built safely etc
Threads: 28
It's all very well saying that if I'm asking these questions then I shouldn't be building a cage. But firstly how else do I find out? I've looked at pictures and seen both done. Secondly you've not actually managed to answer the question as to which is preferred?
If people could pop some piccies up for me it would be very much appreciated
Threads: 141
35
its real strange with insurance, every safety modification you make usually increases the price more than power or handling mods....
guess it would be because having a rollcage, buckets and harnesses etc give you the confidence to drive harder and faster
Threads: 465
114
Car Model/Spec: Vauxhall
Peugeot 306 Challenge - Multipoint
Price: £688
Fitting + cage kit: £1617
Peugeot 306 Challenge Clubman - 6 Point
Price: £480
Fitting + cage kit: £949
Peugeot 306 F2 - Multipoint
Price: £772
Fitting + cage kit: £1938
Peugeot 306 F2 Clubman - 6 Point
Price: £480
all prices +vat
http://www.customcages.co.uk/homepage
Threads: 0
45
If anyone is worried about a cage increasing your insurance - give me a PM. The modified car polices I can quote you with won't be increased with a cage, infact in some cases it can reduce your premium!
Threads: 28
Thanks for the piccys and info guys. Was wondering if anyone has any pictures of the rear installed/being installed as I cant find any hugely detailed ones.
Threads: 55
17
(23-05-2013, 06:41 AM)floz123 Wrote: It's all very well saying that if I'm asking these questions then I shouldn't be building a cage. But firstly how else do I find out? I've looked at pictures and seen both done. Secondly you've not actually managed to answer the question as to which is preferred?
You don't find out, it's part of the reasoning/design...:/
And as I say, mine bolt to the beam
Threads: 130
82
Car Model/Spec: 106 GO-NAD
(23-05-2013, 08:23 AM)JJ0063 Wrote: If anyone is worried about a cage increasing your insurance - give me a PM. The modified car polices I can quote you with won't be increased with a cage, infact in some cases it can reduce your premium!
*coughcough* you get my pm Jordan?
Threads: 90
And me ^^
Threads: 28
Okay cheers for the help rippthrough. Do you happen to have a picture of how you do the rear to the beam by any chance?
Cheers
Threads: 55
17
Threads: 13
Car Model/Spec: 306 Rallye // Saab 9-3 Aero.
Threads: 150
14
God damn that's beautiful
I need
Threads: 55
17
That one was a fair bit tbh, as it has triangulation through to the front turrets, roof bars, etc, and some gusseting too.
Threads: 28
Decided I'm gonna mount to the arch now  after reading bits and bobs. Might brace it across to the beam mounts but that would only be to stiffen up a bit. Nice cage though mate
Threads: 55
17
Can I ask why? The main struucture at the rear of a 306 is where the beam mounts are
Threads: 28
I am tempted to do both if that's allowed? Was reading some blue book bits and it said something about trying to keep bracing bars etc as close to the inside of the body panels as in the event of an accident, the body won't have to move as much before it hits the cage and therefore reducing further potential risks and injury. I'm not saying for a second this is the correct way to do a 306 but i think its how I will be doing it. Always open to advise and positive input though.
Dan
Threads: 55
17
I generally get away with it by not sitting in the boot.
Threads: 169
91
I think dan was coming more from the angle of the fact that regulations state a parameter for roll cage-bodyshell distance.
Going to the arches will conform with this and he is asking if the beam mount will aswell. Not if he can fit buckets in the boot
Threads: 55
17
03-06-2013, 10:45 AM
(This post was last modified: 03-06-2013, 10:46 AM by Rippthrough.)
They don't state one, they suggest one, and it's for the safety cell (i.e. main hoop, a-pillar hoops, roof bar, door bars), not the supporting bars. (rear stays, rear diagonal, turret bars, etc)
