30-05-2013, 01:58 PM
Also where to get parts ?
Cost roughly for fmic kit for hdi 306?
30-05-2013, 02:24 PM
there's a guide in the guides section you could have a look at mate. Considered doing mine at a point, you could head to a breakers and look for a 110 hdi 406 to get the top inlet elbow and the bottom turbo pipe is off a c5 iirc. Shouldn't be dear.
Then you will need an intercooler which are cheap enough off eBay with a piping kit. And you will also need slimline fans
30-05-2013, 02:34 PM
(30-05-2013, 02:24 PM)rd070707 Wrote: there's a guide in the guides section you could have a look at mate. Considered doing mine at a point, you could head to a breakers and look for a 110 hdi 406 to get the top inlet elbow and the bottom turbo pipe is off a c5 iirc. Shouldn't be dear. Thanks for the info think I will at some point after couple of other plans take place
30-05-2013, 02:37 PM
about £350 I would have thought if youre buying things new!
30-05-2013, 02:39 PM
Dont need slimline fans, its up to you... i never ran them on mine
30-05-2013, 05:11 PM
Yeah, depends whether you're happy to risk cooking your engine in traffic or not lol.
I've done mine for about £100, others have spent anything up to a grand, all depends how you do it and how much time/effort you put in. Don't forget about the clutch though, whether it'll hold or not is partially down to luck, partially down to how you drive it.
30-05-2013, 05:34 PM
Just have one fan! 12" or 15" are the sizes on ebay i think.
30-05-2013, 05:35 PM
lol!
12" and 15" are deffiantly not the same size! xx
30-05-2013, 09:21 PM
About £200 in total, new cooler, and pipes, the elbows from here and you dont need fans, just open your windows and stick the heaters on full blast thats what i had to do the other week.
30-05-2013, 11:55 PM
Anywhere from £100 to £1000 as poodle says mate. If your gonna buy all new bits from ebay and peugeot then budget about £500
31-05-2013, 03:43 AM
I will be selling a complete fmic kit for a hdi in august
31-05-2013, 08:26 AM
31-05-2013, 07:56 PM
(30-05-2013, 09:21 PM)PE02KHG Wrote: About £200 in total, new cooler, and pipes, the elbows from here and you dont need fans, just open your windows and stick the heaters on full blast thats what i had to do the other week. That's what I've been having to do, I have two slimline fans, clearly they aren't working! ![]()
01-06-2013, 05:32 PM
Cost me around £450, most expensive part was a big twinpass cooler. Didn't fit any fans, just have to make sure you don't stay still for long.
And yes, clutch. Don't go oem thinking it might hold, I made that mistake, few hundred miles later it started to slip. Should have just bought uprated from the start!
03-06-2013, 09:03 AM
So your doing away with the original fans ? If you don't fit slim line ones ?
03-06-2013, 10:17 AM
You'll have a hell of a job fitting a cooler with oem fans. In fact, it just won't fit.
I was just being tight and didn't want to buy fans, and I've not once seen the temps go above 85c. The scanguage tells me exactly what's going in, so it's all good.
You can get a cooler in with the oem fans, but it needs to be pretty slim and the right shape, itll be a struggle to plumb in too.
03-06-2013, 11:33 AM
03-06-2013, 03:44 PM
The OEM fans take up a huge amount of space, you can get a sensible sized one off ebay for £20
03-06-2013, 10:05 PM
Will look into this more after I have couple more plans sorted thanked for the info
28-09-2013, 01:20 PM
Does anyone have any pics of the bottom turbo pipe and the inlet elbow of a 110bhp engine ??
28-09-2013, 01:28 PM
I'm selling a complete kit for £200.
Includes clamps and everything
28-09-2013, 03:57 PM
28-09-2013, 04:39 PM
I got the guts of my bits for 80 quid, just need a few more silicones and thats me
28-09-2013, 04:53 PM
No more than £20 I'd imagine
28-09-2013, 06:56 PM
Mine added up to around 300.
Id firstly get the inlet lower pipe and 90 onto the turbo first and work from there. And im happy I didnt scrimp with my clutch.
30-09-2013, 10:04 AM
Well I've sourced a full fmic kit here for £150 all I need are the 110 pipes
30-09-2013, 10:14 AM
I costed a full new twin pass FMIC kit with mikalor clamps and it was £360
30-09-2013, 10:19 AM
This is a new kit
With clamps and all Not sure what type of cooler it is though |
| Bumper, Bonnet, paint job cost | steve1001 | 1 | 2,938 |
02-10-2018, 06:20 PM Last Post: steve1001 |
| Injector rebuild / Rough cost | mcglynn | 8 | 4,711 |
18-08-2014, 05:58 AM Last Post: Poodle |
| Cambelt change cost? | C.A.R. | 7 | 5,746 |
03-07-2013, 10:39 AM Last Post: Ricky |
