Cold weather veg running?
Been sticking straight veg into the tank and its been fine upto today when its started pissing down and now won't start. So whats the recommended mix of diesel to use or even something that will thin it down abit in the bottle?
TD04 11mm Sedan, now 2.1 vnt
Provence Dturbo Dead
Blaze 1.6 Dead
Some people use a small amount of petrol in a full tank of veg, something like 2 litres is enough to thin it down. Or use half a tank of diesel.
Not sure how cold it is where you are. But i am using 10% diesel atm, in winter i was using 5-10% petrol.
Peugeot 206 GTI HDI
Volvo V50 2.0d
Volvo XC90 D5
Mine still started on straight veg even when it was almost freezing... How's the fuel filter?
Fuel filters new changged it day before last. Its ⁴ here on the car clock
Blaze 1.6 Dead
Hmmmm around the same here, im starting fine and driving fine with 10% diesel
Peugeot 206 GTI HDI
Volvo V50 2.0d
Volvo XC90 D5
checked ya glowies mate? . . .should be fine in this weather .Smile
4 degree's is about the temperature you start to struggle, esp if it's dipped lower during the night.
Veg emulsifies before water freezes, so low single figure numbers give you a right arse ache with 100% Veg.
Best cold weather mix is:
5-10% Petrol (for thinning)
10-15L Diesel (for performance, cold idle stabilisation)
100-200ml 2-stroke oil (for pump & injector lubrication)
40L Veg oil
I ran that mix in the depths of winter, car starts like a champ first time and runs brilliantly.
Just pour a kettle of hot water over the pump to get her running. Then run 10% diesel
I ran straight veg all through winter and never had issues. Weird.
Can't have got that cold by you.
Is the car garaged or under a car port or something?
When veg gets to 0 degree it's more like jelly, it won't pump, it won't inject and it won't flow past a filter.
Frigging nightmare if you get caught in a cold snap before you've switched to a winter mix.
The car can be out of action for days until it warms up enough to start.
Just out on the street been mixing 10% diesel and seems ok bar cold idle
Blaze 1.6 Dead
(29-05-2013, 12:28 PM)HDIkyle Wrote: Just out on the street been mixing 10% diesel and seems ok bar cold idle
cold idle is always fcuked mate . .keep revs up and get used to it lol
It idles ok even when first started just cuts out when you rev it. i have bumped it afew times at junctions without even realising what had happened
Blaze 1.6 Dead
(29-05-2013, 12:54 PM)HDIkyle Wrote: It idles ok even when first started just cuts out when you rev it. i have bumped it afew times at junctions without even realising what had happened
ahh air getting in by sounds of it then mate . . . .
Yea something's not right I ran pure veg and had to shovel the snow to get the car out fired straight up
Team Doesn't own a 306
this car used to cut out at junctions mate when i first bought it, turned out to be air getting in . .Smile
  Running too cold? WiNgNuTz 10 4,738 09-04-2014, 09:56 PM
Last Post: Toms306
