D Turbo tuning.
(22-05-2013, 11:32 AM)Anton Wrote: Just wind the actuator in and control the boost with fueling. Or better fit an MBC, bugger keep adjusting the actuator!
How can you control the boost with the fuelling? Or is that down to the winds on the compensator? A MCB would be so much more easier
3 x Peugeot owner.
1996 106.
1996 306 D Turbo S.
1994 Mercedes Benz 320E.
1997 306 GLX.
#32
You will only make so much boost if theres so much fueling. I can make my GT20 make 30psi or 8psi by limiting the fueling....
Peugeot 206 GTI HDI
Volvo V50 2.0d
Volvo XC90 D5
#33
(22-05-2013, 11:24 AM)ADV_93 Wrote:
(22-05-2013, 11:16 AM)Mattcheese31 Wrote:
(22-05-2013, 11:01 AM)ADV_93 Wrote: I did mate Big Grin! I have read how some people have had to turn it 3 or 4 times to get it doing anything! But driving it, feels like it's boosting a lot more than 10 i tell ya! Gonna have a crack later with a boost gauge try and get it higher! Cambelt and oil change friday hopefully!
wind it ALL the way in then back it off half a turn mate, that's the way to do it . .Smile
Haha! What boost will that be running then? 26+?! Only aiming for 18!
depends on fueling . . . .i'm running about 24psi peak . .Smile
#34
(22-05-2013, 11:16 AM)Mattcheese31 Wrote: wind it ALL the way in then back it off half a turn mate, that's the way to do it . .Smile
Is this controlled by the max fuelling and compensator combined? If not can you explain how plehs Smile
3 x Peugeot owner.
1996 106.
1996 306 D Turbo S.
1997 306 GLX.
#35
Just to confirm a few points here.
The engine will be pretty much as reliable as stock as long as you look after it. Ive seen inside 130k engines that have run big boost for a while and you can still see the hone marks on the cylinders and the bearings look nearly new.
The ph1s are starting to pop head gaskets because of their age, the oldest are over 20 years old but this should be seen as to be expected on a 20 year old car and the go on standard cars and boosted cars.
Youll struggle to wound the engine on a stock pump and turbo no matter how tuned they are.
Id also heard that Peugeot had to de-tune the engine to stop it ruining sales of the XSi as apparently it was as fast before they de-tuned it.
A FMIC is good for keeping your intake temps low and prolonging the life of your turbo, with a good set up its possible to have your intake temps lower than ambient temperature.
Regular oil changes with reasonable quality oil are a must and make sure you use a pug filter as they are the best quality. Every 6000 miles was the OEM interval, some people are doing it every 5k
It is possible to control the boost with the fueling as if there is no fuel you wont make any boost. On my first DTurbo I ran the wastegate arm solid so it would never open and just controlled the boost by the fueling. A maxed 9mm bosch pump will do 32psi on diesel and 30psi on veg with a DWG T2
#36
(22-05-2013, 11:41 AM)Anton Wrote: You will only make so much boost if theres so much fueling. I can make my GT20 make 30psi or 8psi by limiting the fueling....
It's as simple as winding the wastegate fully in and then setting it up with max fuelling?
(22-05-2013, 12:22 PM)Dum-Dum Wrote: Just to confirm a few points here.
Thanks for those notes pal!
3 x Peugeot owner.
1996 106.
1996 306 D Turbo S.
1997 306 GLX.
#37
i wouldn't wind it fully in myself, leave it there as a safeguard imo mate . .Smile
#38
(22-05-2013, 02:03 PM)ADV_93 Wrote: It's as simple as winding the wastegate fully in and then setting it up with max fuelling?
You can and its the easier than doing it properly but it makes it very easy to repeatedly over speed the turbo and this will wear it out quickly, you'll also get epic compressor stall when you change gear and if its violent enough this can break the blades clean off the compressor wheel and then suck them into the inlet (worst case scenario). That said it sounds EPIC
#39
a: Closing a wg is NOT 'tuning'
b: turning the actuator to achieve more than 18 causes horrible lag between 18 and max boost. fit a dawes type mbc its only 10-15 quid ffs
b: your not 'controlling' anything with fuel your limiting fuel with no wg
Its the truth I swear lol hate to harp on about this in different threads but the op seems like a guy who wants yo do it properly
#40
As epic as compressor surging sound is, i know it is of no benefit to the turbocharger. Seen a turbo that had done that before... Messy, i don't think getting the engine out and rebuilding it or swapping it is quite worth a "tssss" when you shut off...
(22-05-2013, 09:24 PM)con67 Wrote: a: Closing a wg is NOT 'tuning'
Yeah, i wanted to do it the proper stage 1 way tbh, the winding wastegate in fully and controlling with the fuelling was the first i ever heard... I need an 8mm nut and a boost gauge then i can hopefully get the stage 1 finished! Also, did a 0-60 run yesterday (on a closed off, quiet national speed limit road) and using 2 separate stop watches, got it down to 9 seconds on 2 runs... And i've not even tuned the boost yet...
3 x Peugeot owner.
1996 106.
1996 306 D Turbo S.
1997 306 GLX.
#41
I need help with something! Today i went to turn the boost up on my K14 and as i wound in the threads, it decided to thread then pop itself straight out into my hand? Me, shitting myself thought that the turbo would lose nearly enough all boosting force. Tried to do a simple bodge of some form of long bolt to try and create a resistance on the wastegate spring (to give me some boost) and it wasn't having any of it... However, got in my car and drove home to find the car was still boosting and pulling like usual? Do i have a seized wastegate or is this something to do with the fact i've turned the fuelling up so it helps the turbo to boost? It'll have to do in the mean time until i can get my hands on a T2 turbocharger!
3 x Peugeot owner.
1996 106.
1996 306 D Turbo S.
1997 306 GLX.
#42
you won't notice a difference between a k14 and a T2 imo mate . .Smile
#43
(24-05-2013, 11:54 AM)Mattcheese31 Wrote: you won't notice a difference between a k14 and a T2 imo mate . .Smile
Even if the boost goes above 20 PSi?
You got any idea what this wastegate madness is all about pal?
3 x Peugeot owner.
1996 106.
1996 306 D Turbo S.
1997 306 GLX.
#44
My t2 ran 26 ish psi and was fine! Now changing for td04 as waste gate problems on the t2
Silver Five Door D-Tuurbo'! More Doors More Whores y0! Wink
#45
(23-05-2013, 11:37 PM)ADV_93 Wrote: I need help with something! Today i went to turn the boost up on my K14 and as i wound in the threads, it decided to thread then pop itself straight out into my hand? Me, shitting myself thought that the turbo would lose nearly enough all boosting force. Tried to do a simple bodge of some form of long bolt to try and create a resistance on the wastegate spring (to give me some boost) and it wasn't having any of it... However, got in my car and drove home to find the car was still boosting and pulling like usual? Do i have a seized wastegate or is this something to do with the fact i've turned the fuelling up so it helps the turbo to boost? It'll have to do in the mean time until i can get my hands on a T2 turbocharger!
Plug the hole and fit an mbc, it should work fine Smile
#46
Where do you connect an MBC to on a KKK K14? It's an internal wastegate?
3 x Peugeot owner.
1996 106.
1996 306 D Turbo S.
1997 306 GLX.
#47
cut the metal pipe that runs to either end and take it off there . .Smile
#48
(25-05-2013, 08:45 AM)con67 Wrote: Plug the hole and fit an mbc, it should work fine Smile
Is that the metal pipe that runs off the induction side of the turbo? What does the pipe do?
3 x Peugeot owner.
1996 106.
1996 306 D Turbo S.
1997 306 GLX.
#49
That pipe feeds the actuator boost, nip an inch out of it then connect two hoses to your mbc on each side youve cut.
#50
(26-05-2013, 10:03 AM)con67 Wrote: That pipe feeds the actuator boost, nip an inch out of it then connect two hoses to your mbc on each side youve cut.
Ran boost gauge today and she's running 12/13 PSI when driven. Gonna mount boost gauge tomorrow and get a MBC too! Try and get her boosting 18-20 PSI!
3 x Peugeot owner.
1996 106.
1996 306 D Turbo S.
1997 306 GLX.
#51
first things first before getting boost giddy have you just gone over your piping to check for cracks and boost leaks? because imo once youve done wastegate and fuel even a little bit there usually boosting about 16psi. just a quick heads up save you f*cking about if you can save some time just getting new hose instead of doing wg and pump again
Official Team Go-NAD fan club
#52
i put my boost {screw} actuator all the way in clockwise,my max fuel screw all the way in and back a quater of a turn and my wastegate actuator on the turbo all the way in and back 1 full turn so i got more max power and when the it comes on boost it flys at 25 psi on a lucas with k14 mate and i aint had any probs apart from my clutch need replacing,lol.
#53
(28-05-2013, 02:23 AM)the milkman Wrote: first things first before getting boost giddy have you just gone over your piping to check for cracks and boost leaks? because imo once youve done wastegate and fuel even a little bit there usually boosting about 16psi. just a quick heads up save you f*cking about if you can save some time just getting new hose instead of doing wg and pump again
first thing i'm gonna do when i can get underneath the car! hopefully when this friggin rain stops! Seems to be boosting around 12/13 consistently though! Gonna check the air feed to the turbo and the compression piping to the intercooler... Get that MBC ON! 18 or 20 PSI, can't make my mind up!
(28-05-2013, 06:01 AM)bayley Wrote: i put my boost {screw} actuator all the way in clockwise,my max fuel screw all the way in and back a quater of a turn and my wastegate actuator on the turbo all the way in and back 1 full turn so i got more max power and when the it comes on boost it flys at 25 psi on a lucas with k14 mate and i aint had any probs apart from my clutch need replacing,lol.
Might have to turn it up to 20! Got no screw on the turbo, the screw fell out! Need to fit an MBC now to control boosting...
3 x Peugeot owner.
1996 106.
1996 306 D Turbo S.
1997 306 GLX.
#54
will drive better at 25-26 psi.bet your boost is all over the shop with a screw being missing
#55
(29-05-2013, 05:53 AM)bayley Wrote: will drive better at 25-26 psi.bet your boost is all over the shop with a screw being missing
I was expecting that, but it hold 12/13 psi all day long and still pulls like a train!
3 x Peugeot owner.
1996 106.
1996 306 D Turbo S.
1997 306 GLX.
#56
I wouldn't over work these small turbos, yes people say they run them at 300000000024 psi all day and its fine, in reality they just don't flow efficently and makes them wanna go bang I'd say 20 is about right for small turbos
#57
(29-05-2013, 11:11 AM)the milkman Wrote: I wouldn't over work these small turbos, yes people say they run them at 300000000024 psi all day and its fine, in reality they just don't flow efficently and makes them wanna go bang I'd say 20 is about right for small turbos
to be honest mate, i'm not looking for 163.7's bhp, just a standard stage 1 tune. Fuel pump is done and only need to fit an MBC to turn the boost up as the actuator adjuster is nackered. No point running more than 24 PSI on a TMIC, and i'm only aiming for 20 tops. 20 is enough to embarrass folks so i'm happy at that!
3 x Peugeot owner.
1996 106.
1996 306 D Turbo S.
1997 306 GLX.
#58
Oh how times have changed lol
3 x Peugeot owner.
1996 106.
1996 306 D Turbo S.
1997 306 GLX.
#59
Indeed haha [SEE-NO-EVIL MONKEY][SEE-NO-EVIL MONKEY]
#60
Lololol
3 x Peugeot owner.
1996 106.
1996 306 D Turbo S.
1997 306 GLX.
  gt2260v turbo tuning wategate depression niciou 8 6,187 09-03-2016, 09:25 AM
Last Post: Dave
  1.9d non turbo tuning karl1989 9 5,616 07-12-2015, 07:26 AM
Last Post: THE_Liam
  Turbo Tuning - Help! philpemberton94 22 11,600 21-05-2014, 01:30 PM
Last Post: philpemberton94
