Head gaskets
Okay so I stripped the funked head today and when I took the whole fuel filter housing off the head the gasket broken, is there a proper gasket for it or not?
If you buy a head set you should get a new one included
GT2052s DTurbo
OEM+ HDI Estate
Project thread
Ok thanks Smile
I just used some gasket sealant, £3 a tube
And how's it holding up?
Was fine, still is, heads been on 3 different engines since and still fine. Clean up your surfaces well, thin layer on one of them, bolt together 80% tight, then after a day or so I always nipped them to what I normally would, so then your squashing the set rubber.
  Help sourcing gaskets... doogle-d turbo 6 5,073 17-08-2017, 08:30 AM
Last Post: doogle-d turbo
  where the best place to buy head gaskets daniel909 20 8,862 12-10-2014, 04:52 PM
Last Post: londondan86
  Gaskets for turbo adaptor plates Ben 12 9,091 02-05-2013, 12:50 AM
Last Post: samass
