Rear light change.
Picked up a set of rear lights at the weekend. When I came to fit the I found the loom layout is slightly different, in that the original set has two plugs and the new lights have just one plug type and two separate cables.
Two questions 1st what do the 2 wires illuminate I got every thing else fitted and all the light seemed to work so cant figure what theyre purpose is.
2nd is it just a case of getting a couple of adaptors or soldering the in?
Are you going from p1 to p2/3? If so there's a guide up in the guide section I think
HDi Cabby Project Click
Thanks must have missed that. Its just the spare two wires on the near side light. Ill have a look at the guid and play with them at the weekend see if I can get to the bottom of it
[Image: 2jcaw6b.jpg]
The 2 spare wires are for the number plate lights bud
the wiring diagram in the guides section isnt perfect, i wouldnt advise cutting any pugs off unless your fairly confidednt with automotive electronics
The OP has a HDi, so what lights are you changing to? Not Lexus lights I hope....
(16-05-2013, 04:45 PM)Toms306 Wrote: The OP has a HDi, so what lights are you changing to? Not Lexus lights I hope....
Well spotted Tom. Lexus lights need to die by fire
Ill get some pgotos up when I get a moment. They were a car boot bargin, but would be good to find out a bit more
If you going from phase 1 to 2/3 you can just use Lexus looms in the phase 3 light shells. I will be selling mine soon.
  Phase 1/2 rear light wiring diagrams. ADV_93 1 2,705 04-09-2014, 02:45 PM
Last Post: doogle-d turbo
  Phase 1 rear light wiring PartyJas 1 1,921 10-07-2014, 12:29 PM
Last Post: Frosty
  Rear light cluster Aaron _d95 4 3,783 23-09-2013, 07:14 PM
Last Post: Aaron _d95
