Brake fitment
Brake fitment
I have a x reg 1.9 L diesel. Will gti 6 calipers fit straight on?
yes, but you may need to use spring washers to space the calliper bolts out as the hubs are sometimes different and you'll need 15" wheels also . Smile
Are the Gti breaks defiantly bigger than what I have? As I checked euro parts and the same calipers came up on both vehicles????
Gti brakes are definitely bigger the disc size on yours atm are 247mm on your car and 283mm on gti brakes. So just a little bit biggerSleepy
The difference is night and day though, a well worthwhile upgrade. As Matt said though you may need the bolts as well.
HDi Cabby Project Click
Do the master cylinder aswell though
(16-05-2013, 08:22 PM)puglove Wrote: Do the master cylinder aswell though
I never bothered but it is supposed to give a more progressive feel to the pedal but I found it fine without
