Struggling to rev
Struggling to rev
Hello
I am having trouble with my car, it struggles to rev and really judders. It's only started recently. Anyone have ideas as to what it could be. It's very annoying when it does it!
Cheers
Dan
Fuel filter? Touched anything on the pump recently?
I have changed the filter. Not messed with the pump. It's on a standard Lucas.
I've just drove the car home and it was horrible to drive, was very juddery and felt bogged down. The engine also cut out a few times. I'm stuck as to what it is. So any help is appreciated.
Cheers
Bosch of lucas? Could be air getting in somewhere?
pickup filter in the tank?
does it start straight away?
any fuel leaks?
(12-05-2013, 10:21 PM)Tom Wrote: Bosch of lucas? Could be air getting in somewhere?
he's already said its a lucas!
Not checked the pickup filter. Yeah starts first time. I just put new glowplugs in. Not got any fuel leaks that I can see of.
have you had anyone plug it in? might have some silent codes.. never know. how long before it started running rough did you fill up? could be some bad fuel, had it before..
It's only started over the last couple of days. Full tank in it, was pretty close to the orange zone before I filled up. I changed the filter as thought it was that but it's still doing it. It's on an S(98) model so not sure if it can be plugged in.
^^^plug it in?! Hmmm....be great to see what results he would get! rofl
It's a dturbo, not an hdi ^^
306 HDI, soon to be XUD
urghh i blame lack of sleep, no concentration lol but its getting fuel to start, so maybe a faulty pump?
Mine did this, I changed fuel filter, intank pump, injector seals and found out I had 2 f*cked injectors
Fabia vRS PD130 - New daily
Astra H VXR - new toy!
Cheers Dicky. I'll look at them next. Will bosch injectors work with the Lucas pump?
Just to add some more info to this.
I have replaced the fuel filter housing now thanks to Karl1989 after breaking mine stupidly.
However the car seems to be getting alot of air bubbles in the fuel line that leads from the top of the housing to the fuel inlet on the pump. I can see them as its see through hose on there. Also the car idles ok before starting to be very erratic and drops down very low on the revs and then dies. It also does this while the car is been driven and will suddenly cut out and then struggle to start.
I'm at a loose end now and don't know what is causing it.
Thanks
  XUD struggling after 4k Dan! 15 9,993 15-12-2011, 07:27 PM
Last Post: jammapic
