Threads: 12
hi ive recently lowered my axle done it by taking out the torsion bars and adjusting the height so the original height was 420mm its now 375mm but i have shortened dampers on the bk the arm needs jacked up 45mm so the bolt can go through the damper it then gives me a height of 330mm and its far too low ave never had to jack an arm up nearly 2 inch to get the damper in
do you think my dampers r far too short when i bought they were stated for a xsara n6
Threads: 12
yip its still low about 20mm + of the tyre sits inside the arch
Threads: 208
60
30-04-2013, 05:55 PM
(This post was last modified: 30-04-2013, 05:56 PM by puglove.)
Lowered it to much then bro, need to take the TBs back out ,
Threads: 12
cheers mate will do that then
i'll raise it another 30mm
Threads: 208
60
Tryed pressing them out, and they kept snapping the the hardest bolts i could get my hands on, And they were pretty Dam hard bolts
The try'ed the good old try'd and tested sledge hammer, still not a bean, This is all after 2 weeks of regular plus gas & cleaning
Next thing to do is drop the beam out and get the heat on it.
Threads: 136
Oh right sounds like you've had a good go then. When you say you tried pressing them do you mean pull? Like with a plate over the trailing arm and then the bolt through the plate into torsion thread?
Threads: 12
the old axle was a b***ard sledge hammer and heat never worked on that tried everything just aswell my old man had a new axle there for the car lol
Threads: 208
60
Yeah i may end up changing mine, iv got an old drum beam kicking about
Threads: 12
well ave just raised mine so its sitting pretty nice now drivers rear end sits 7mm higher because its on uneven ground lol but its all the same height
just waiting on some countersunk screws and a feeler gauge
