	Threads: 32
 Car Model/Spec: '96 306 1.4
		Hi guys. Where I work exist one supercharged from a g40 to sale.
my engine is the old monoponit. Anyone know anyone who have adapted the charged to this engine?
I'm interested on this now xD
![[Image: sign.png]](https://lh3.googleusercontent.com/-QC0ySJzJ_vU/Tz-FRT2KPTI/AAAAAAAACDs/caChZQn3zg0/s500/sign.png)
↑ Project ↑
	Threads: 141
 35
		i don't think anyone has or ever likely will bother supercharging a 1.4 306. the amount of work you would have to put in and the money you would have to spend would massively outweigh any of the benefits you would get from charging.
the best value for money in terms of money for power is the xud engine, don't know how easy they are to come by over in portugal though :/
	Threads: 100
		Guy at ace supercharged a gti engine on a budget of £1500. So not a massive amount of money.
	Threads: 32
		but XUD is diesel. This is only an ideia xD
What i have in mind its the 1.6 8v, but now I knew that I wanted to see if there was someone with a charger :p
↑ Project ↑
	Threads: 130
 82
 Car Model/Spec: 106 GO-NAD
		Never heard of it done before, I say go for it, it'd be awesome!
	Threads: 141
 35
		 (15-04-2013, 11:15 PM)Pompey306mark Wrote:  Guy at ace supercharged a gti engine on a budget of £1500. So not a massive amount of money.
I bet that was only because so many parts already exist for charging the '6 engine, you would pretty much have to start from scratch if you did a 1.6
then there's the issue of the terrible 1.6 gearbox, doubt it would handle the extra power very well, along with the huge list of other custom parts you would need such as uprated injectors, better cooling system, ecu programming, bigger pump, cams.
 i doubt the notorious 1.6 gearbox would handle much of a power increase, you would also need to re balance the crank since your going to have to add another pulley for the charger belt.
and last but not least, the actual gains from charging such a small engine wont be that noticeable since the charger leaches about 10% of engine power just to run it in the first place.
thats my thoughts on it anyway
	Threads: 541
 124
		THey sell yurbo kits for the 1.4 saxos so the ecu has to be able to cope with boost, thatll be your best line of research.
	Threads: 141
 35
		turbo would be a better option tbh, much better gains and cheaper
	Threads: 541
 124
		nah you want to fit both lol.
	Threads: 100
		By the looks of things most of the 205 gti 6 engine was custom. I have seen the standard kit and this wasn't it.
	Threads: 208
 60
	Given 5 thank(s) in 5 post(s)
		id check out 106owners & saxP for advice on this topic
		 (16-04-2013, 12:22 AM)Pompey306mark Wrote:  By the looks of things most of the 205 gti 6 engine was custom. I have seen the standard kit and this wasn't it.
It was. I had a long chat with him. The entire thing was home brew. None of it was from a kit. The actual parts cost him £600 for charging and battery relocation then £400 on the ecu and £500 for mapping
	Threads: 55
 17
 Car Model/Spec: 406 V6
		 (15-04-2013, 11:40 PM)Dum-Dum Wrote:  THey sell yurbo kits for the 1.4 saxos so the ecu has to be able to cope with boost, thatll be your best line of research.
Not with the archaic bosch monopoint system though, it can barely cope with a light breeze.
	Threads: 36
 18
 Car Model/Spec: DT
		I'd say give it a go.. Good for 150hp I guess!
On the 306 waiting list.
		 (16-04-2013, 09:54 AM)Rippthrough Wrote:   (15-04-2013, 11:40 PM)Dum-Dum Wrote:  THey sell yurbo kits for the 1.4 saxos so the ecu has to be able to cope with boost, thatll be your best line of research.
Lolz, rising rate pressure regulator for a complete lack of control how fuel going in ftw!!!
	Threads: 90
		lol as Ruan says, just run after market fpr and blow boost down the inlet, be reet, would cost under 500 quid to bolt an M45 on the side of it, and then you get chronic charger win ftw also.
	Threads: 32
		so wat I've to buy to put in the 1.4?
charger
intercooler
pressure regulator
eco tune
more what?
↑ Project ↑
	Threads: 96
		Little bit off topic but I had a 1.6 8v which I got a charge kit for I only saw 150 bhp for around 1800/2000 not worth it swap the engine out for a 2.0 then charge it
