Threads: 59
Can't seem to find much info on these.. I have a set 16".
What width are they? Offset etc? We're they original Peugeot ones or not? What tyre size do I need for them? 205's?
Any info appreciated!
Threads: 56
19
Car Model/Spec: Moonstone HDi
At a guess they'll be 6.5j et19 ish should tell you on the inside of the wheel
Youll want 195 45 16 tyres
And yes they are original pug wheels, came with the sp pack
Threads: 56
19
The reason id run 195s is because thayll get you closer to oem rolling radius
Threads: 59
Would 195's stretch a bit then? And they're wider than cyclones then?
Threads: 56
19
Cyclones are 6j.
Na you wont get any stretch with 195s, if you want a bit of stretch go for 185s
Threads: 56
19
Youd get away with them I think but ideally you want 195s
Threads: 119
Car Model/Spec: MG ZS180
195's are ever so slightly stretched. You saw the 195's on my alloys didn't you? They are exactly the same.
Threads: 59
Okay.. I wanted to get Yokohama parada spec 2 tyres.. But they don't seem to do them in 195 45... Will 205 make that much difference? :/
Threads: 119
205's would be better imo.
Threads: 56
19
No youll still get them on, im just not sure what width the sp's are.
Go with there is hardly any difference between 195 and 205s just 195s are closer to oem rolling radius
Threads: 92
43
Pretty sure theyre 6.5" and the difference is only 10mm... Personally Id be getting 205s
Threads: 541
124
205/45 is closer to oem rolling radius than 195/45
Threads: 59
Ok, so 205 would fit ok and look 'right'..
Threads: 119
When I next get a set of tyres I will be getting 205's. Only got 195's because they were a bargain.
