Loss of power, likely due to clogged fuel filter?
Video
My fuel light is useless on the 205 and I think I almost ran it down to the bottom of the tank. Since then I've lost top end power and sometimes if I'm lucky it will have full power briefly (the boost shoots up and it pulls well for a second). Ill be doing the oil, filter and fuel filter but just wanted to check what it could be!
Supercharged GTi6 Build
S14 Zenki Build
[Image: signature.png]
Maybe fuel filter and try and blast the fuels with an airline, that should help !
Disclaimer - I think it would be ok to blow back thought the fuel lines with an airline but check with someone else first Smile
[Image: siggy1.jpg]
Yeah fuel filter more than likely!
Yeah sounds fuel filtery aha
It was indeed fuel filter as I thought.
Ill get a picture up when I'm on a PC later.
It's hands down the worst fuel filter I've ever seen!
S14 Zenki Build
Ooooooooooo sounds juicy!
Some pictures:
1
[Image: IMG_0404_zpsef2b0717.jpg]
2
[Image: IMG_0403_zpse17d7206.jpg]
3
[Image: IMG_0400_zpsc2a48a16.jpg]
4
[Image: IMG_0399_zps5d862c45.jpg]
S14 Zenki Build
what in fcuks name have you been putting in your tank?!!! do you run waste veg oil? . . :o
Haha. Tongue
I've literally ran it purely on diesel as its still on a lucas atm!
Sickening isn't it!
Going to do the oil and filter this week too as if the fuel filters in that state then...
S14 Zenki Build
(16-04-2013, 10:18 AM)silverzx Wrote: Haha. Tongue
Sickening isn't it!
summit wrong there mate . . . god knows what but that is seriously wrong . lol
The tank could probably benefit from a good clean, is there anywhere else I should check how blockages?
S14 Zenki Build
(16-04-2013, 10:41 AM)silverzx Wrote: The tank could probably benefit from a good clean, is there anywhere else I should check how blockages?
by the look of that filter i'd clean the tank out and change filter again in a few weeks . .Smile
Zzz, how would I go about cleaning the tank? Does it drop down from underneath or?
S14 Zenki Build
(16-04-2013, 01:46 PM)silverzx Wrote: Zzz, how would I go about cleaning the tank? Does it drop down from underneath or?
lot of faffing about mate, is this a 205 or 306 btw? . . . .306 tank is accessed under rear seat, maybe just syphon fuel out and clean out the sludge . .Smile
(16-04-2013, 01:52 PM)Mattcheese31 Wrote: lot of faffing about mate, is this a 205 or 306 btw? . . . .306 tank is accessed under rear seat, maybe just syphon fuel out and clean out the sludge . .Smile
205.. Blush
S14 Zenki Build
Exclamation Swarf In Fuel Filter Housing jordanhdi 11 6,462 26-09-2016, 11:55 AM
Last Post: pug306driver
  Removing the fuel filter housing, but what is this behind it? Iaitoo 2 3,225 27-04-2016, 05:33 PM
Last Post: Iaitoo
  Drove 150+ miles with clogged fuel filter - now won't start mikes 21 11,510 13-04-2016, 07:17 AM
Last Post: mikes
