Threads: 170
hi guys so i have no brakes. well the pedal is at the bottom and touches floor does stop but its not good. it has ABS. recently fitted a brake cylinder in the rear drum and the bleed nipple came loose not long after so lost all fluid. sorted it out now they have gone again. changed master cylinder and they did'nt build any pressure to bleed them but with abit of time i got pressure and the the brake pedal was near the top  but now i am getting full travel again to the floor  . also the pipe that runs across the top of engine normally bolts down to the TMIC were it bends there is a T piece it seems to be blowing/sucking air in so have blocked that off if people get were i mean. sorry for the cr*p write up.
cheers karl
Venetian XUD ph2 heaven
Ph3 perv cab heaven
Black ph1 XUD died
Moonstone hdi stage 2
Erm, sounds like you have no servo assistance...you need that vacuum pipe between the servo and the engine...
Threads: 170
the metal pipe?
Ph3 perv cab heaven
Black ph1 XUD died
Yeah, it should go from the brake servo to somewhere on the engine (vaccuum pump on an XUD I reckon), without it your brakes will be the same as they are with the engine off.
you've made your brakes rubbish!
Why did you do that?!
Threads: 226
24
Car Model/Spec: A3 TDi
Somethings f*cked by the sounds of it... How does the pedal even get stuck on the floor? Surely that means theres completely no pressure in the system, like a seals broke or something? Sure you dont have a bleed nipple open or something? Or the master cylinder is shot?
Threads: 31
7
Sounds like you are pushing all the fluid out, Is the Brake fluid pod still full up?
maybe he decided to disconnect other usual pipes?!
Threads: 541
124
It wont be a servo issue if the pedal is going to the floor, you have air in the system and/or a fluid leak.
Check for leaks and bleed the whole system with fresh fluid.
Threads: 22
6
Car Model/Spec: 306 HDi Stage 1
^this, servo/vacuum issues make the pedal as hard as hell.......
Threads: 170
The pedal does'nt get stuck on the floor! It travels to the floor hence no brakes hardly. Yes theres still fluid in there i changed the master cylinder too. Will have a double check over it again at the weekend
Ph3 perv cab heaven
Black ph1 XUD died
Threads: 541
124
Gotta be a leak or air bubbles if your going to the floor.
I've gotta say it's not the best description lol, I didn't even realise the pedal was going to the floor. If thats the case then I agree with the above, a leak somewhere. Dd you only change one brake cylinder? Maybe the other ones popped and dumped the fluid into the drum?
Threads: 62
10
(11-04-2013, 03:56 PM)karl1989 Wrote: Yes theres still fluid in there i changed the master cylinder too.
having it incorrectly fitted would also cause your issues. Are you sure you fitted it correctly?
Likewise, borked master cylinder seals would put the pedal to the floor.
HDi Owner for 200k/9 years
Threads: 6
or buggered rear brake shoe adjusters.
Threads: 170
Yes i only fitted 1 cylinder. Theres no fluid leaking that i can see. Also the brake pedal gets pressure when the car is turned of but when running they dont build any pressure
Ph3 perv cab heaven
Black ph1 XUD died
Yeah, that just proves the servo is doing it's job.
You've either got a CHRONIC airlock or it's pissing the fluid out.
Threads: 31
7
If you're not losing fluid then i'd say definitely Airlock issue.
You been bleeding them properly? you start closest to the master cylinder and pump slowly to get the air out.
Threads: 79
17
Start at the furthest isnt it?
Threads: 541
124
Have you definitely checked every centimeter of the braking system and all around the calipers and drums on a perfectly dry day for the leak as sometimes they are very good at hiding.
Threads: 170
(12-04-2013, 05:38 AM)Rich306 Wrote: If you're not losing fluid then i'd say definitely Airlock issue.
its furthest away. going to do them tomorrow
Ph3 perv cab heaven
Black ph1 XUD died
Threads: 31
7
(12-04-2013, 12:05 PM)PE02KHG Wrote: Start at the furthest isnt it?
Lol my bad :O
Threads: 170
rear brake cylinder gone. went for a long drive and noticed its decided to bust the seal on it
Ph3 perv cab heaven
Black ph1 XUD died
the other cylinder or the one you replaced?!
Threads: 170
the other one. cant wait to get the HDI axle on now
Ph3 perv cab heaven
Black ph1 XUD died
Threads: 252
7
The other one it is
TD04 11mm Sedan, now 2.1 vnt
Provence Dturbo Dead
Blaze 1.6 Dead
Threads: 170
ye the old one not the new one
Ph3 perv cab heaven
Black ph1 XUD died
Woop...I was right then...second time round lol. Exact same happened to my ph2 1.4!
81
definite leak. My 1.4 I ran out of fluid and the pedal went to the floor and i couldnt stop... yay!
Threads: 170
the problem is the rear cylinder found out ages ago
Ph3 perv cab heaven
Black ph1 XUD died
