Threads: 202
58
Does anyone have a wiring diagram for one of these? I'm a bit stumped TBH, I can only get the backlight to work, the gauge wont give a reading..
Threads: 90
54
I have a HKS gauge, wiring is pretty simply, should be two spare wires with connectors on the end that you dont need / if you connect together should sweep the gauge to test...
Ill try and get down workshop later and take a photo, dont use it anymore.
Threads: 202
58
Cheers mate that'd be great if you could. Just to check, if I connected it up and heated the thermocouple with a cigarette lighter, it should read shouldn't it?
Threads: 90
54
Nah wouldnt be near hot enough..
Put a blowtorch near the end of it / heat gun and ull start to activate it
Takes few seconds for probe to warm up / react also
Threads: 129
11
How much was it/where was it from? I'm looking to get one.
Stage 2 XUD Sedan
Threads: 90
54
I bought a stack one after that as my HKS one was always really dodgy for some reason, think it costs about 120 iirc
Threads: 25
1
Car Model/Spec: Dturbo
Given 1 thank(s) in 1 post(s)
Jonny did you ever sort the wiring on this?
I have a HKS gauge as well with the following wiring colours;
Yellow
Grey
White
Red
Black
Any ideas?
My thoughts would be;
Yellow - ?
Grey - ?
White - ?
Red - Positive
Black - Negative
Threads: 25
1
Yellow - illumination
Red - Ignition +ve
Black - Ground
White/ Grey - Join together to set the warning light level.
