08-04-2013, 10:16 PM
How do I change this as mine is due a service
Diesel filter
08-04-2013, 10:23 PM
Take off the 4 allen bolts on the top of the housing, take the filter out. Suck the diesel out the housing, and clean any crap inside the housing you might have, put a new filter and seal in and put the lid back on. Use the hand primer and squeeze until it goes hard, crank the engine a few times, it will start and your done.
08-04-2013, 10:30 PM
Dont forget hes non turbo!
Only seen one on a 206 so cant help. So easy tho, big black thing in front of you, open it up swap filters Prime either with bulb or a button (206) and start ![]()
Simple as that does a new seal come with a new filter ?
(08-04-2013, 10:30 PM)Oil-burner Wrote: Dont forget hes non turbo! Should have mentioned that its a NAD sorry
08-04-2013, 10:40 PM
i changed one on a N/A 405 the other day and its the same as my dturbo, and yes a new seal comes with the new filter.
08-04-2013, 10:41 PM
Cool what's best way to suck the diesel out
(This post was last modified: 08-04-2013, 10:42 PM by Oil-burner.)
Fair doos, the 206 one is quite wierd.
It may be different tho as its a ph3. Suck the diesel out of what? Lol ![]()
08-04-2013, 10:45 PM
I just use a massive Syringe lol. its not essential to get the diesel out and clean the inside, but its just good practice to do so.
08-04-2013, 10:49 PM
Cool so in theory it's a 5 min job then thanks guys
08-04-2013, 10:50 PM
(08-04-2013, 10:46 PM)Oil-burner Wrote: Theres a bleed nipple on the bottom of the housing never knew that!
08-04-2013, 10:54 PM
Its usually got an open ended clear pipe coming from it but sometimes they get lost etc
09-04-2013, 11:05 AM
i don't drain the housing, takes longer to fill up if you do . .
09-04-2013, 06:10 PM
(09-04-2013, 11:05 AM)Mattcheese31 Wrote: i don't drain the housing, takes longer to fill up if you do . . Do you just pull the old filter out and put the new one in then ??
09-04-2013, 06:12 PM
Yeah I dont bother draining the housing either, theres over a quids worth of diesel in there!
09-04-2013, 06:19 PM
Just take the lid off, pull the old filter out, and put the new one in...trying not to drip deisel everywhere.
09-04-2013, 06:23 PM
You had any problems doing it this way
09-04-2013, 06:37 PM
Shouldnt be any problems, diesel comes up through top of housing iirc so any bits that may be there shouldn't get sucked up anyway.
09-04-2013, 06:56 PM
Only reason why i drain mine out is because when i had a Lucas pump, i found small metal filings in the bottom of the housing. (pump breaking down gradually) I've now converted mine to Bosch and i don't find metal fillings, but i still do it out of habit anyway
09-04-2013, 07:52 PM
yeah tiz bit of a waste of fuel to empty completely...worth draining a few ml though as its officially a water drain I believe, to drain off any H2o in the housing
09-04-2013, 08:07 PM
(09-04-2013, 06:10 PM)Willo Wrote:(09-04-2013, 11:05 AM)Mattcheese31 Wrote: i don't drain the housing, takes longer to fill up if you do . . yep, take it out, tip the fuel back into the housing and then plonk new filter in .
09-04-2013, 08:14 PM
wrap a cloth around the filter housing before you take the top off, prevents diesel spilling all over the starter motor
09-04-2013, 08:50 PM
(09-04-2013, 08:14 PM)ozonehostile Wrote: wrap a cloth around the filter housing before you take the top off, prevents diesel spilling all over the starter motor and clutch sometimes if you get it really wrong Wishes for more power...
09-04-2013, 09:14 PM
(09-04-2013, 08:14 PM)ozonehostile Wrote: wrap a cloth around the filter housing before you take the top off, prevents diesel spilling all over the starter motor yes yes this . . . .forgot to say that deffo . .
10-04-2013, 11:16 AM
(09-04-2013, 08:50 PM)Piggy Wrote:(09-04-2013, 08:14 PM)ozonehostile Wrote: wrap a cloth around the filter housing before you take the top off, prevents diesel spilling all over the starter motor What happens if you get diesel on the clutch? will it dry out eventually?
10-04-2013, 02:44 PM
(09-04-2013, 06:56 PM)Marcus1991 Wrote: Only reason why i drain mine out is because when i had a Lucas pump, i found small metal filings in the bottom of the housing. (pump breaking down gradually) I've now converted mine to Bosch and i don't find metal fillings, but i still do it out of habit anyway really??? how did the metal filings go full circle from the pump all the way through fuel system tank n back to filter??
10-04-2013, 02:51 PM
(10-04-2013, 11:16 AM)Chris_90 Wrote:You might be lucky and it might dry, or might be unlucky and it will f*ck your clutch completely.(09-04-2013, 08:50 PM)Piggy Wrote:(09-04-2013, 08:14 PM)ozonehostile Wrote: wrap a cloth around the filter housing before you take the top off, prevents diesel spilling all over the starter motor Make sure you don't snap the allen bolts like I did 'just once more around with a little nip make sure their fine' then snap.
Fabia vRS PD130 - New daily Astra H VXR - new toy! |
| High flow diesel filter | MarkHam | 5 | 3,145 |
15-07-2014, 08:14 PM Last Post: zx_volcane |
