d8a
d8a
will a d8a cylinder head go fit on a normal xud9 engine block? without no tricks or cons?
Yes...
D8a, d8b , DHY all heads are the same.
On the 306 waiting list.
There not the same....but yes they will all fit.
[Image: sigi-2.png]
(07-04-2013, 07:07 AM)darrenjlobb Wrote: There not the same....but yes they will all fit.
Hmm. Porting? Or cams?
There's some interesting cam speculation going on at the minute...
andy, that engine you have is a d8a anyway when gav put it in if i remember right
Nah identical in that respect, the later DHY ones just have steel inserts between the valves to help prevent the common cracking issue (makes a big difference) there are also some other subtle differences like bolt holes on the side, and webbing around injectors, but not stuff that makes any difference to anything.
[Image: sigi-2.png]
Cheers all and padge your vac pump is mint just tried it on mine and brakes even better so it was deffinatly not that Smile
haha thanks mate Wink
