06-04-2013, 11:02 PM
will a d8a cylinder head go fit on a normal xud9 engine block? without no tricks or cons?
d8a
07-04-2013, 07:07 AM
There not the same....but yes they will all fit.
07-04-2013, 09:40 AM
07-04-2013, 12:11 PM
andy, that engine you have is a d8a anyway when gav put it in if i remember right
07-04-2013, 04:13 PM
(07-04-2013, 09:40 AM)cwspellowe Wrote:(07-04-2013, 07:07 AM)darrenjlobb Wrote: There not the same....but yes they will all fit. Nah identical in that respect, the later DHY ones just have steel inserts between the valves to help prevent the common cracking issue (makes a big difference) there are also some other subtle differences like bolt holes on the side, and webbing around injectors, but not stuff that makes any difference to anything. | Dyno Power Runs & Steady State Facilities Available, Just Ask Anytime |
07-04-2013, 09:00 PM
Cheers all and padge your vac pump is mint just tried it on mine and brakes even better so it was deffinatly not that
