30-60mph in 3rd times??
I've just realised i've tried timed runs with a boot full of bull bars, tool box, car parts, a roof rack with a spare wheel, medi box, shovel, f*cking all sorts. Must be pulling a good 1400+kg including the driver.
Yeah i thought those times were a little slower than I hoped lmao
Book figures appear to be unladen weight of around 1200kg, 0-60 14.1 seconds and top speed of 112mph. Yeah I think I blitzed that.
Makes 24psi by 2.5krpm, happy days. Actually peaks earlier than that if you mat it from 1500rpm or so, but the torkz just spins the wheels up
#32
your car sounds so good when you come off boost
Does sound well that pellowe, the plasmas make it difficult to see whats going down. The GT20's dont appear to take long at all to come on full blow... Think i'll take a vid of 30-70 in 3rd now im running dumb boost but i time mine around 6 seconds with a change into 3rd gear, think i hit the mapped in rev limiter in 3rd at 4200 there, need to get my map tweeked again really but ive got to be happy with that on this set-up, the paddle clutch has definitely improved gear changes for me.
Wheres jonny....
S2 HDi >click<
154bhp
280lbs/ft
#34
Yeah mine really needs some tweaking but I might empty out the boot etc and go for another run tomorrow. Think I can probably scrape a couple more psi from it safely too.
For the weight it's lugging about at the minute, that's really not that bad I don't think, especially seen as it needs properly tuning. Might try one 2nd-3rd and a 3rd-4th too.
#35
Get some close ups of the dials if you can?
Weight is a big killer in these cars i think, i can feel a massive difference once my tank is nearly empty compered to when its full.... Carnt wait to get mine gov modded so i can see what it can actually do. Smile
#36
Cant wait to build another one of these!
http://youtu.be/ZWE5ixKG4Iw
#37
What was the specs on that con67??
Bit off topic but what damage will it cause going to 5,000rpm+ ??
#38
Just timed the sedan at about 7 seconds 30-70. The 2.1 carries on pulling at that rate upto 100mph
2nd gear launch con? Be good to see a flat 30 to 70 of that.
Ozone whats the gearing like in the 2.1, same as a 1.9?
S2 HDi >click<
154bhp
280lbs/ft
#40
the sedans using a hdi box
Had my pump gov modded now, still not great on acceleration boosting 24/26psi
http://www.youtube.com/watch?v=LJ5W8CkE5-c
Seems to feel alot quicker when im going though the gears but when i did this vid seems slow as fook, it is on a strong veg mix tho so that wont be helping.
@CJ can you get a vid up of yours?? wana see what its like
#42
(05-04-2013, 11:25 AM)Chris_90 Wrote: What was the specs on that con67??
Shimmed gov, terranno dvs, e300 merc k14 at 30psi, hdi box.
Mine never threw rods or anything in 4-5years, took that abuse quite alot, but 5k+ is playing with fire in every way id say rods/hg lol
(05-04-2013, 03:05 PM)Arron Wrote: 2nd gear launch con? Be good to see a flat 30 to 70 of that.
Didnt launch at all mate just booted it a mph or 2 below 30 in second.
#43
How do i upload on youtube? Will it work if i upload from photobucket?
Ive only got one from other week with leaking manifold which i dont make 60 just hit 55 then hard on brakes as some fucker pulls out lol
Will try get one tonight on way home n sus uploadin via youtube buddy
[Image: J5hxCcC.jpg]
#44
Just go to youtube and hit 'upload'.... lol
You do need a gmail account though if you dont already have one. In my experience the photobucket videos never seem to work properly so you're better off with youtube...
#45
(08-04-2013, 08:44 AM)CJ_Derv Wrote: How do i upload on youtube? Will it work if i upload from photobucket?
Yer you need a gmail account easy to sign up tho, but u can put it on photobucket and link put a link to the vid on here to
#46
Right sussed it i had a gmail account how do i get the link onto here then? Bearing in mind in on samsung S3
Ive only the 30-55 with leaky mani but IMO doesnt seem too bad for 2100revs on a laggy turb
https://www.youtube.com/watch?v=S3U3w8oN...ata_player
#47
(08-04-2013, 09:04 AM)CJ_Derv Wrote: Right sussed it i had a gmail account how do i get the link onto here then? Bearing in mind in on samsung S3
Looks alot quicker than mine just on that small pick up, do a propa one if you can Smile 30-70
#48
It picked up slightly better than that now will do one tonight and will do one from second and show you difference that buildup makes on mine, just remember im running a 15g not a 13t so could make a slight difference although not much
#49
http://www.youtube.com/watch?v=0f03XfRZxjs
That was with a chronic boost leak and i had 2 passengers... one had a massive head
#50
Sounds epic CJ. Looks like it pulls well once its on blow
S2 HDi >click<
154bhp
280lbs/ft
#51
(08-04-2013, 09:29 AM)Arron Wrote: Sounds epic CJ. Looks like it pulls well once its on blow
Il defo get another today after work n upload tonight does sound epic de-filtered and with stainless pipe with just backbox
Everyone says sounds mint from behind but never heard it frrom outside car may have to get someone drive it so i can hear it
#52
Last nite 2 mates in and heavy sub think i need strip ot for summer Smile
https://www.youtube.com/watch?v=f4kWo_Uw...ata_player
https://www.youtube.com/watch?v=9x9pm-rr...ata_player
#53
Looks good CJ really dose sound good de-filtered, weight is a big killer in these, mine feels like it goes like fook now my fuel tank is nearly empty
#54
I duno if its just me but does anyone elses seem perkier at times than others, this wasnt a bad run but felt like it had more poke this morning but it was colder and denser
#55
Well theres your answer cj, every 10 degress drop in charge temp equates to something like a 3percent increase in power, at least with NA motors anyway
#56
I though so ive an amazing drive to and from work over top roads n theres a good straight so will do the 30-60 again in colder conditions and compare Smile
And beed to dyno this again now its runnin right Smile
#57
(09-04-2013, 07:15 AM)Chris_90 Wrote: Looks good CJ really dose sound good de-filtered, weight is a big killer in these, mine feels like it goes like fook now my fuel tank is nearly empty
But the trade off there is that the rear end is a little slipperier due to lack of weight over the beam.... Confused
Anyway, dunno why you guys complain about lag on XUDs....this is lag... lol
http://www.youtube.com/watch?v=umYosXIvr...e=youtu.be
Think I broke'd it.... Doh
#58
(09-04-2013, 08:44 AM)CJ_Derv Wrote: I though so ive an amazing drive to and from work over top roads n theres a good straight so will do the 30-60 again in colder conditions and compare Smile
Think we need to set up a dyno meet in the midlands as i wana get mine on, even tho it will probably depress me lol
#59
What was that big smash noise as it came on boost?!
#60
http://www.youtube.com/watch?v=MGIT49N86...e=youtu.be
das mine...
kkk turbo at 26/27psi, 11m pump, gov modded, lda ground, tmic, buggered head and quite sure despite the 26/27psi that I have a boost leak
not sure if its much cop
just to add, 100% veg oil!
30-60 is roughly 5seconds
i think the 30-70 is about 7.3seconds
  50-80 acceleration times. daveylennon93 17 10,757 17-07-2014, 08:59 AM
Last Post: kelvsere
  Sad Times Are Sad c.gerrard 15 8,101 30-11-2013, 08:51 AM
Last Post: darrenjlobb
  probably been asked a million times before... LewisG306 3 3,198 04-10-2013, 03:01 PM
Last Post: Piggy
