Threads: 93
8
Car Model/Spec: Stock HDi Meridian & Mk2 MX-5
Given 1 thank(s) in 1 post(s)
03-04-2013, 11:13 AM
The HDi failed its MOT today, as expected:
So I can confirm an airbag light is now a fail, thanks to Cully that shouldn't be too much of an issue though.
Other questions:
1. Who/where can I get a set of braided brake lines from, and what's the going rate?
2. Where can I get TRE balljoints, what brand do you guys recommend?
3. As it's so close to passing, can I just tighten the handbrake from the cabin while I'm fiddling with the airbag ECU, or do I have to do it at the rear calipers?
Also, do we think it's feasible to get everything by Friday morning, as the garage closes at the weekend, and I need to drive back to Brum on Sunday?
![[Image: sigcopy-1.jpg]](http://i570.photobucket.com/albums/ss147/KEZZIEBOY/Diablo%20HDi/sigcopy-1.jpg)
Threads: 56
19
Car Model/Spec: Moonstone HDi
TRE balljoint? Its just a track rod end.
They have a balljoint on the end where it attaches to the hub.
Brake lines try ebay, im sure someone was saying they do kits pretty cheap.
Other than that theres someone on here that can supply them iirc.
You might get away with tightening the cable if its not far of.
Threads: 91
12
Car Model/Spec: 306 D Turbo
Swampy on here does braided lines. I got a full kit for £48 delivered
Threads: 93
8
Yeah I thought it was just a TRE, just reading the fail sheet
And was that front and rear Dan, as I only want fronts.
Threads: 30
Car Model/Spec: Hdi-dturbo stage 1
03-04-2013, 12:06 PM
(This post was last modified: 03-04-2013, 12:08 PM by wonkey18.)
Should of gone to Jamie zamboonies :/
I have a nearly new track rod end if you need one
Threads: 138
72
Car Model/Spec: Mincebus
TRE's, I'd recommend Lemforder, you can get em from ECP for about £12 iirc...
I got Goodridge braided lines from http://www.brakes4u.co.uk/supersearch.as...8982&won=1
You're better off going to Swampy though, his are cheaper! Sure I didn't pay as much as that site are now selling them for!!
Astor 'X' 4 GTi6- 6 - SOLD!
Threads: 386
87
Tres from ECP as said.
Braided lines...you'll struggle to get those before Friday imo. Could get some normal ones at Ecp though.
Handbrake....err, you can't tighten it at the calipers not like drums, just adjust at the lever inside....either that it new cables if the others have stretched.
Threads: 591
54
yeah...or maybe service the calipers too?!
Threads: 93
8
03-04-2013, 01:05 PM
(This post was last modified: 03-04-2013, 01:34 PM by Kezzieboy.)
I'm guessing the TREs are the same both sides? Might as well do the pair while I'm at it, which means I can't really afford lemforders (unless they really are worth the extra £5 per side?).
Wonkey I always go to PAC as they're really thorough, means my car is 100% okay after the MOT and is more likely to make it 12 months without dying  I may take you up on that TRE though, what do you want for it?
I've pm'd swampy, hopefully he'll get back to me, I cba to fit the lines myself so they'll be getting done at the garage anyway, and as such only need to be here by friday afternoon.
Anybody got a phone number for swampy? Going to put a next day delivery order in with ECP and need to know whether or not to add brake lines to that order :/
Threads: 138
72
Meh, if you're strapped for cash I'm assuming the alternative is Q-part? Just bung em on  Make sure you get the car tracked after fitting though!!
Threads: 93
8
Q-Drive or Ocap, yeah.
Threads: 386
87
03-04-2013, 06:10 PM
(This post was last modified: 03-04-2013, 06:10 PM by Toms306.)
Definitely dont go for Q-Drive! Buy cheap buy twice definitely applies to Q drive parts lol. Can't say I've had anything 'Ocap' though.
Don't forget you'll need to add ~£30 to have the tracking done after the TRE's are changed as well....
Threads: 581
195
Tbh tracking isnt essential. You can count off threads on the old one and count them on on the new and it will be as near as perfect as to what it was before.
Threads: 386
87
I've changed several TREs and despite counting and measuring, they never were perfect....plus you're old ones are probably out now anyway.
Its worth it in the long run to save killing tyres though.
Threads: 92
43
Given 2 thank(s) in 2 post(s)
(03-04-2013, 06:15 PM)Niall Wrote: Tbh tracking isnt essential. You can count off threads on the old one and count them on on the new and it will be as near as perfect as to what it was before.
Load of bollocks, different TREs have a different amount threads, changed mine the other week and the new ones had more threads
Threads: 581
195
(03-04-2013, 06:45 PM)Connor Wrote: (03-04-2013, 06:15 PM)Niall Wrote: Tbh tracking isnt essential. You can count off threads on the old one and count them on on the new and it will be as near as perfect as to what it was before.
Well yeah that is assuming they are the same length but how long does it take to check they are the same length? If there the same length, its not like they will have different amounts of threads is it?
Threads: 92
43
Yeah you realise straight away, but it throws the thread count straight out the window lol
Threads: 476
81
Car Model/Spec: 306 Rallye
Threads: 581
195
(03-04-2013, 07:01 PM)Connor Wrote: Yeah you realise straight away, but it throws the thread count straight out the window lol
Not if before you take the old ones off, you count the threads from the joint back!
Threads: 386
87
But your old ones were probably already out anyway...every car I've bought has needed the tracking done lol.
And as said, even if you do measure/count its not always accurate.....specially if you aren't concentrating and end up turning the track rod with the TRE...did that on the NAD lol, steering was properly weird with tracking about 2cm out!
Threads: 581
195
Yeah but you always buy shit heap cars tom!
Threads: 386
87
Well I can't argue there....but its even the ones I don't buy as well lol.....the tracking on Rowells estate was (and still is) miles off....
I dunno how people don't notice the tyre wear or the wheel vibration!
Threads: 93
8
Well I no longer give a shit about the TRE's, as my airbag fix hasn't worked. Cock.
Ideas on a postcard?
Threads: 138
72
^^ 6 x resistors from Cully, job jobbed  xx
Threads: 93
8
Keep up Ed, that's what I'm doing!
Threads: 179
21
Car Model/Spec: Broken Phase 2 GTi6
Given 17 thank(s) in 12 post(s)
.depending on he fault you may need to reset the airbag ecu and I might go away
1. Fooby's Car
2. Fooby's Hire Car(s)
3. Fooby's Company Pool Car
Team Self Improvement
1. Learn to Car
Threads: 581
195
(04-04-2013, 09:50 PM)Fooby Wrote: .depending on he fault you may need to reset the airbag ecu and I might go away
And how do you reset it Fooby?
Threads: 465
114
Car Model/Spec: Vauxhall
(04-04-2013, 09:51 PM)Niall Wrote: (04-04-2013, 09:50 PM)Fooby Wrote: .depending on he fault you may need to reset the airbag ecu and I might go away
lol
his airbag fault is not that simple 6 resistors probably wont fix it
but i might be wrong
Threads: 30
Kez you can have it for half the price of a new one? As it's only a few weeks old
Threads: 55
17
Car Model/Spec: 406 V6
(03-04-2013, 07:11 PM)Niall Wrote: Not if before you take the old ones off, you count the threads from the joint back!
But they're not all threaded the same distance from the joint....and the threads aren't orientated the same either....measuring will get you close enough not to worry about it but counting threads is usually a bit of a red herring.
