Threads: 581
195
Have to have the security code to program anything security related but still cant do the central locking if the key was originally from another car. The chips are basically one use. Once there programmed, they generally cant be reprogrammed (although a few people have been able to. i think its a bit hit and miss tbh)
Threads: 24
1
Car Model/Spec: 306 Meridian 1.8 16v (Phase 3)
Given 2 thank(s) in 1 post(s)
Hi Niall
Great guide mate but I got a couple of questions.
I got the security code and Peugeot Planet but i'm confused on what i'm gonna need to make a secondary remote fob.
When you say you can 5 transponder chips does this mean you can program in 5 prewitten chips or do they have to be 5 new chips?
If I gotta get new chips do they have to be Philips PCF7931 or will any ID46 chip work?
For the central locking part will any Peugeot 2 button remote work, ie one from a 206 as long as its the right type [I need the rf type], or does it have to be from another 306?
How will I know if the central locking fob can't be programmed to my car, and does anyone know what the chip is that holds the coding and if it can be replaced?
Looks like transponder chips are easy enough to get hold of, mainly looking for help with getting a secondary remote central locking fob for my Phase 3 306.
Cheers for any advice
Threads: 581
195
With the transponder chip (tiny little black thing jammed in the key casing used to start the car), you can use a second hand one from a second hand key on eBay (usually about £5).
With the CL chip, you will know if it doesn't work because when you press the buttons on the key in the sequence, it will just fail. Need a new chip but as I said, that means going to Peugeot and getting raped for one.
The pre multiplex 206 keys work and so do the very late 106 ones. The early 307 ones could as they share a very similar system but I'm yet to try this!
Threads: 236
36
Car Model/Spec: '01 HDi DTurbo
Niall how much would you charge to get the black immobiliser chip reprogrammed? I appreciate you can't do the C/L reprogram, but I want to replace the key housing and can't remove that little black chip from my working key (scared of breaking it!?) to put it in the decent fob case.
![[Image: Sig500x130.png]](http://i430.photobucket.com/albums/qq25/chris_rx71/Sig500x130.png)
Threads: 581
195
(22-10-2012, 12:58 PM)c.a.r. Wrote: Niall how much would you charge to get the black immobiliser chip reprogrammed? I appreciate you can't do the C/L reprogram, but I want to replace the key housing and can't remove that little black chip from my working key (scared of breaking it!?) to put it in the decent fob case.
ill do it for a drink if you come to the christmas meet and do it there (about half way between us!)
It should come out though. Its only held in with pressure from the casing. Just get a watchmakers screwdriver and prise it out
Threads: 138
72
Car Model/Spec: Mincebus
Niall how do you get into the part of pug planet where you can read the sensors (ie lambda map pressure etc)?
Astor 'X' 4 GTi6- 6 - SOLD! ![Sad Sad](https://www.306oc.co.uk/forum/images/smilies/sad.png)
Threads: 19
5
Car Model/Spec: Ph1 D-turbo(on going project)
good guide, still trying to set mine up.
whats your pc identifier for keygen?
also whee i get server request code?
Threads: 32
2
Car Model/Spec: '96 306 1.4
hi. I know this car dont belong here but.. a friend mine have bought a 206 gt, but we dont know what number of serie it is, and in the Peugeot Portugal cant tell us what is too (lol) with the vin number and on the peugeot planet i can know what serie number it is?
![[Image: sign.png]](https://lh3.googleusercontent.com/-QC0ySJzJ_vU/Tz-FRT2KPTI/AAAAAAAACDs/caChZQn3zg0/s500/sign.png)
↑ Project ↑
Threads: 117
119
Ed, do the usual full system scan or whatever it's called, then go into the ECU and click on parameter measurements.
Threads: 138
72
Done Poodle, cheers mate ![Smile Smile](https://www.306oc.co.uk/forum/images/smilies/smile.png) I kinda worked it out myself just sat in the car playing with it
Threads: 465
114
Car Model/Spec: Vauxhall
14-03-2013, 08:40 AM
(This post was last modified: 14-03-2013, 08:41 AM by cully.)
(14-03-2013, 01:18 AM)Seid Wrote: hi. I know this car dont belong here but.. a friend mine have bought a 206 gt, but we dont know what number of serie it is, and in the Peugeot Portugal cant tell us what is too (lol) with the vin number and on the peugeot planet i can know what serie number it is?
the RPO number or the build number can be found on a sticker on the car
Planet gives instructions on where to find it
if the sticker is missing take the registration date and google PSA build date calculator you should be able to find a tool that will give you a rough build date number
Threads: 117
119
h yeah, was a bit late replying there lol.
Threads: 90
54
For reading sensors, use lexia, you can choose which ones u want to display on screen, and also press record and record a drive, and then it dumps it in a file as a graph / text log...which is nice...
Just choose a cit car with same motor and itl connect to engine ecu no bother.
Threads: 138
72
I've got lexia 3 but not installed yet... I'l have a look cheers mate
Threads: 117
119
Ed, whats this about lexia, fancy lending me the sw there...?
Threads: 138
72
Yeah sure man, I bought this one the other day;
http://www.ebay.co.uk/itm/221189007865?s...1497.l2649
It came with: Lexia-3: V47, PP2000: V24 & DiagBox V6.01
I've only bunged PP2000 on it so far; I hear Diagbox offers more of the later models in the peugeot range, but it's apparently slower than pp, and requires more cpu power (which my cruddy old xp laptop borrowed from work just didnt have!) so I just stuck with pp...
If anyone can shed any light on the other bits though, do let me know. When/if I ever get a half-decent laptop to run pp on, I'll be putting all 3 on to have a play, but until then...
Threads: 19
5
^how you get it setup ed?
im trying on my crummy old netbook, looking for me to confirm keys but dont know how to?
insturctions i got not much use either
Threads: 32
2
17-03-2013, 01:41 AM
(This post was last modified: 17-03-2013, 02:02 AM by Seid'.)
(14-03-2013, 08:40 AM)cully Wrote: (14-03-2013, 01:18 AM)Seid Wrote: hi. I know this car dont belong here but.. a friend mine have bought a 206 gt, but we dont know what number of serie it is, and in the Peugeot Portugal cant tell us what is too (lol) with the vin number and on the peugeot planet i can know what serie number it is?
after all, thanks. i have called to my friend and he dont have that sticker. i already know the production date, vin number, etc but it is difficult to find the serial number -.-
↑ Project ↑
Threads: 465
114
(17-03-2013, 01:41 AM)Seid Wrote: (14-03-2013, 08:40 AM)cully Wrote: (14-03-2013, 01:18 AM)Seid Wrote: hi. I know this car dont belong here but.. a friend mine have bought a 206 gt, but we dont know what number of serie it is, and in the Peugeot Portugal cant tell us what is too (lol) with the vin number and on the peugeot planet i can know what serie number it is?
whats the production date?
Threads: 90
54
build number dosnt matter anyway, just makes it faster as it knows exactly what ecu's to search for, will work either way.
Threads: 32
2
(17-03-2013, 09:04 AM)cully Wrote: whats the production date?
If I was right, the produticon date is 24.06.1999
↑ Project ↑
Threads: 465
114
17-03-2013, 04:58 PM
(This post was last modified: 17-03-2013, 04:59 PM by cully.)
(17-03-2013, 03:47 PM)Seid Wrote: (17-03-2013, 09:04 AM)cully Wrote: whats the production date?
RPO number 8263 is Thursday 24 june 1999
Threads: 32
2
I know that number. But that number is not the serie/serial number. The 206 gt was limited for 4000 units.
↑ Project ↑
Threads: 465
114
try online service box you can put the vin in and find out all about your car
Threads: 32
2
I've used the service box, and it also is not saying nothing. Thanks for the help!
↑ Project ↑
Threads: 52
Car Model/Spec: Ph2 LX TD Estate
anyone local to cannock with planet please?
Threads: 4
Car Model/Spec: 306 HDi est
12-05-2013, 03:25 PM
Thanks for this very useful guide ... so have been looking for the kit to use. Saw this item on eBay for about £70 and wondered how it compared etc?
Lexia 3 Diagnostic interface tool for Citroen&Peugeot - Full setup inc DIAGBOX !
Threads: 117
119
Fairly sure thats virtually the same thing mate, lexia 3 certainly works on our cars.
Threads: 4
(13-05-2013, 10:18 AM)Poodle Wrote: Fairly sure thats virtually the same thing mate, lexia 3 certainly works on our cars.
Many thanks for that - will probably get it then as I'm looking to get a Pug/Citroen van too.
Threads: 19
5
should work fine, diagbox is the program that works with both citroen and peugeot
