starting problems
starting problems
hi folks. ive had this problem a long time and still havent found a solution!
Its a turbo diesel with 11mm pump.
the problem is that it wont start sometimes. it turns over but wont fire... however the slightest of jumps will start it! like i can literally push the car myself and it will start in gear.
all suggestions are welcome, even the simplest!
Thanks!!!
Your batterys shit.
yea but it still turns over!!!! it starts it most of the time. the battery is crappy all the same!
Well if it starts straight away with a jump that tells me somewhere you dont have enough juice.
i use to have this problem. turned out the fuel line was drawinh air from a joint.
Fuel solenoid might not be getting enough juice perhaps and is closing while cranking?
  Xud starting problems, pump!! dave205 20 10,857 02-04-2014, 03:57 PM
Last Post: darrenjlobb
  Dturbo starting problems willJspears 15 7,093 25-10-2013, 02:52 PM
Last Post: willJspears
  Changeing glow plugs on 106 nad/ Starting problems Chris_90 67 37,851 16-10-2013, 06:16 PM
Last Post: Chris_90
