Flexible sealant, exhaust
Is there any other sort of exhaust joint sealant that can be used instead of exhaust paste? I wan't something i bit more flexible for my downpipe, but can't find anything that can take the heat.
GT2052s DTurbo
OEM+ HDI Estate
Project thread
no exhaust paste will be flexible...
why is your flexi blowing?!
Think you mis read it, the flexi is fine, but I need something for the v band connection off the turbo, but I hate the exhaust paste, can never get it to apply properly!
GT2052s DTurbo
OEM+ HDI Estate
Project thread
Surely just a new seal should do the job?!
RTV Silicone sealant :p
(09-03-2013, 09:32 PM)Piggy1987 Wrote: Surely just a new seal should do the job?!
It has no seal, its metal on metal.
GT2052s DTurbo
OEM+ HDI Estate
Project thread
then why does it need to be flexible chap?!
because I basically wanted to put a bead around the turbo flange, let it set slightly then clamp the elbow to it to make a nice seal.
GT2052s DTurbo
OEM+ HDI Estate
Project thread
(09-03-2013, 09:40 PM)Ricky Wrote: because I basically wanted to put a bead around the turbo flange, let it set slightly then clamp the elbow to it to make a nice seal.
but you can do that with normal paste Huh
Well I can't! Sad goes everywhere..
GT2052s DTurbo
OEM+ HDI Estate
Project thread
amateur Tongue
http://www.ebay.co.uk/itm/Heatseal-1250c...1c3080e90a
any flexible seelant is usually silicone based so it will jus melt eventualy better off having a hard time with the exhaust past and it working then having an easy time and it lasting a day Smile
try some dum dum, no not chris as he isnt very heatproof or spreadable, but this stuff:
http://www.amazon.co.uk/Dum-universal-se...B004PZQOF6
it sets rock hard but if you ever need to get the two halves apart again just smack the join wiith a hammer and it shatters so piece of piss to remove again
Meh, youd be surprised about silicone sealant... It will put up with silly temperatures from what ive found!!
Isopan with no hardner Wink
(10-03-2013, 12:31 AM)Tom Wrote: http://www.ebay.co.uk/itm/Heatseal-1250c...1c3080e90a
Think I have some similar stuff around somewhere..
GT2052s DTurbo
OEM+ HDI Estate
Project thread
High temp silicone as Ruan said will take a lot of heat ive also found this, there is still a blob on my turbo elbow and its been there a good while now lol
Weve also used it on mates rs turbo - turbo manifold and had the fucker glowing and still sealed lol
[Image: J5hxCcC.jpg]
  Flexible silicon hose for FMIC? Toby 8 4,583 19-03-2012, 03:55 PM
Last Post: silverzx
