URGENT: bosch wont pump ADDED VID P3
Yep getting fuel from both banjos. And used the lucus bracket but moved the studs round.
#32
Gotta be a pressure problem, not pumping enough, did u try with the delivery valves out?
#33
No i havnt. Wil do it now
#34
I'm out if ideas then mate sorry hope you sort it
Team Doesn't own a 306
#35
If it shoots out itll b a pressure problem IMO, mine did it and as I said was buggered lol gd excuse for 11mm haha
#36
Welllllll. With the valve out it splutters a bit of fuel not mass amounts though. Must be a pressure problem. Is this fixable or a whole new pump?
#37
Did it come straight off a car or was it sitting around etc? Could be vane pump seized up etc
#38
Its been sat in my garage for a year eith some fuel in it. Might have to get ruan round and see if hes willing to strip it down on the car :/ sooo pissed off.
Gti isnt MOTd and the xsi goes off the road next week so if i dont get this running im screw'd
#39
Feck it iv given up for the day.
#40
Banjo bolts in the right way, fuel in has big hole, fuel out has small hole, it's worth a look,
#41
Yup, defo the correct way
#42
This sounds like the problem I had when I first built my 11mm, it must of been a head fault but it had sat around for about 4 years, just change the head in off it went, maybe the vain pump is partly sized,
#43
This one has been sat for some time,
do you mean the LDA housing or the top of the pump its self (under the LDA housing, where the throttle arm is attached?
#44
You have to strip the pump completely down to free off your vain pump, I mean head as in the bit the injector pipes bolt into on the back of the pump,
#45
Yeah that's what happened to mine, the shaft on the head snapped lop
#46
Might take it apart. Iv got nothing to loose atm. Do i just undo the nut in between the 4 injecter ports
#47
Check out the 11mm head guide, that covers most of what you need to do
#48
Ok cheers dan. Is it easy enougj to follow for someone whos never openes up a pump before?
#49
I don't think its difficult, just a few fiddly bits.
GT2052s DTurbo
OEM+ HDI Estate
Project thread
#50
Dosnt look or sound to hard but that dont mean feck all lol
#51
Just take your time, maybe get a seal kit for when u put it back together
#52
(04-03-2013, 10:09 AM)dturbopeck Wrote: Just take your time, maybe get a seal kit for when u put it back together
Pffftt iv got a tube of clear mastic. lmao
Well i'll try it and if it works and builds pressure i'll get a seal kit for it
#53
As you said you have nothing to loose so you might as well have a go stripping it down. Might as well gov mod it while your there! Just be careful lifting the top off as the governor is attached to the leverset. If you get stuck post up, we are all here to help! Smile
HDi Cabby Project Click
#54
What would happen if say i was to pull it abit hard on the gov? Would it be fooked or saveable? But yeah fook it im going to start ripping it down when i get home tonight and theres no point in me gov modding it. Its only a 20psi T2 daily work horse to lug shit about in and for the mrs to take to work from time to time .
#55
The other way to do it is to remove the throttle arm then gentally tap the throttle shaft down into the pump (once you have removed the 4 allen bolts) this will leave the gov shaft attached. It's always worth gov modding, especially if you are lugging crap about 6krpm ftw!
#56
Hmmm i think i may do that to be safe knowing my luck the shaft is prob tight as fook. Also i havnt got the parts needed to gov it and i just want the thing running ASAP lol
#57
Right so iv got the head off the pump and its full of fuel. with the head off the pump and the injecter lines disconnected can i turn the car over with my finger of the black lever thing that the gov attaches to and see if i have presure?
#58
What model is your car? Probably imobiliser. Try a direct connection from battery to solenoid.. Should start Smile
#59
(04-03-2013, 07:11 PM)RePT Wrote: What model is your car? Probably imobiliser. Try a direct connection from battery to solenoid.. Should start Smile
Thanks mate. But solinoid was the first port of call. Waaaayyyyy post that.
Little update.
Iv got the pump apart and broke the fork on thats attached to the bottom of tye throttle arm shaft is it a raplacable part??
#60
If you put a pic up of what you broke I no doubt have one lying around you can have, I've got lots of old broken pumps,
  Slack in bosch pump? dt_ 14 12,390 21-10-2020, 03:41 AM
Last Post: dt_
  Bosch pump help for newbie PugRy 2 4,631 05-01-2020, 09:09 PM
Last Post: jamie182
  Bosch pump fuel screw broken Forby 0 3,207 12-03-2019, 06:47 PM
Last Post: Forby
