FAO Ginge191 - pipes
I'll see if its long enough phill, the 406 pipe I've got keeps blowing off and hangs stupidly low.
[Image: sig.jpg]
#32
Ok np. Ill send you one of the other 2. Still sealed in their bubble wrap lol
#33
Phil - a company can make it up for me with:
1 x 90deg silicone 57-51 reducer
1 x straight alloy coupler
1 x 90deg silicone 51mm bend
you reckon there would be enough room for this?
4WayDiablo Wrote:
Chris Wrote:Phill, is that bend in the last pic a 90* and a 2.25"
If so how long are the legs on it and how much do you want for it?
[Image: IMG_20120129_151347.jpg]
17 cm of 2.25" completely straightness on either side of the 90
I have 3 of the 90's ginge only wants 2 ... 8quid poated to your door?
Might be the photo... but thats a funny looking 90 degrees...
i think its 92* ninja
ginge191 Wrote:Phil - a company can make it up for me with:
Phillip?
Phillip?
didnt see that there lmao
my pipes are 57mm? am i missing something?
#38
im assuming that the 57-51mm is irrelevant which way it goes round??
true but why is there another 51mm 90 bend? surely that should be a 57mm no?
#40
Im assuming the joiner pipe is 51mm? i shall enquire
joiner pipe? so confused? so your going
51mm 90 / 51- 57mm 90
to make the u bend to send it gearboxwards?
#42
4WayDiablo Wrote:joiner pipe? so confused? so your going
yes, and a joiner pipe to join the two 90* together... as 90 + 90 = 180 :geek:
this is the only viable way to create a U bend from turbo at 51mm to piping at 57mm Smile
A 51mm u bend then 51 - 57 adapter then straight pipe?
#44
oui!
turbo -> 51mm 90* -> joiner pipe -> 51mm - 57mm 90* -> straight pipe....
Or just get 1 x 180 bend 51mm then get a 51 - 57 adapter is what i was trying to say
#46
4WayDiablo Wrote:Or just get 1 x 180 bend 51mm then get a 51 - 57 adapter is what i was trying to say
ohhhhhhhhhhhh i get you! that could make more sense i suppose, saves faffing around, id still need a joined pipe as i cant just pop two pieces of silicone together, right? unless you have some odd 51mm pipe?
edit: 180* 51mm -> joiner pipe -> 51mm - 57mm
http://www.ebay.co.uk/itm/Black-Silicon ... 1750wt_854
http://www.ebay.co.uk/itm/Alloy-hose-jo ... 1e603e356e
http://www.ebay.co.uk/itm/SILICONE-NOME ... 3368b73e06
They do solid pipe ones. Stainless 51 to 57. Then i have some 57 straight silicon perfect to join.
The third pic on the first post. The red pieces
#48
http://www.ebay.co.uk/itm/51mm-57mm-ALL ... 4aa785c660
BOOM! i'll crack on and order now! Smile
OH and i may need a 90* silicone piece to get round the engine??
You said you would get that lol ive got stainless 90's we can cut down if you want...?
#50
4WayDiablo Wrote:You said you would get that lol ive got stainless 90's we can cut down if you want...?
yeh i'm just ordering now so im re-affirming to myself, you can keep that intact mate Smile
I'll buy the 51mm ubend, metal adapter and 90degree silicone - should be plenty full!
