Gov mod help!
Gov mod help!
Question
Ok so done a few gov mods now and starting to wander if thers more can be done here? I cant seem to find info on this but the middle spring on the governor can it be modified in anyway? Or what else can i change
You need to read this forum there's stickied guides
Its for mid throttle, and the wee tiny spring at the end is for none/idle, looking through vw sites it the spring people first started to shim, but it doesn't really do anything useful being shimmed
The main spring we mod for more revs n to stop the fuel cutting is really all that's needed
If you shim it, the car will seem to have a mind of it's own...
It stops any of the load compensating functions of the throttle, so ends up with the car producing adequate power at a given throttle position, then seemingly produces less when you reach a hill and then seemingly produce more when you start going downhill...
Ok so best left alone then? Or is ther anyway to sort this
Just leave the intermediate spring alone! No need to touch it.
