File Line Function
/global.php 961 eval
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
File Line Function
/showthread.php 1651 eval
Car won't start? Starter Motor?
Exclamation
Today after I finished work the 205 wouldn't start, it appeared to be flat as a pancake.
I had to get a bump start and drove it to my field / workshop and put the battery on charge for at least 2 hours.
After having charged the battery I immediately started it and it was fine, I then drove home 5 miles and parked it up for an hour. After the hour passed I went to start it and it wouldn't start again so I had to jump it.
The lights weren't dimmed down or anything which I thought was strange.
Does this signal the starter motors dead? If so are they easy enough to fit? The 205 is using the XU7 one on the XU9 atm so if it's easy enough I'll pop a XU9 one on there.
Any suggestions / advice is much appreciated!
Supercharged GTi6 Build
S14 Zenki Build
[Image: signature.png]
Sounds like alternator to me.
Starter motors make a horrible grinding noise when they are on there way out.
On the 306 waiting list.
Well I've got a new alternator belt to fit as my current one on there is shredded slightly but that shouldn't stop the alternator from working should it?
Also the car was driven 5 miles and left an hour after being fully charged and then failed to start?
S14 Zenki Build
Sounds to me like your battery has given up!
Mmm... I've got some spare so I'll charge one right up and swap it over. Hopefully it's that simple.
I've been told starter solenoids are commonly at fault for starting issues.
S14 Zenki Build
Ill speak to you tomorrow at some point mate
Oh-ar, look forward to it me lover.
S14 Zenki Build
give the starter a knock with a hammer, hard piece of wood etc when you try and start it...if it goes, points to jammin starter
I reckon battery has given up or could be a dodgy earth on the battery.
Bye Bye D-Turbo
Sounds like your battery to me, swap another one onto it and see..
(17-02-2013, 11:41 PM)Piggy1987 Wrote: give the starter a knock with a hammer, hard piece of wood etc when you try and start it...if it goes, points to jammin starter
this is worth a shout . . .done this on a few cars before . .Smile
Make sure the battery terminals are clean and greased up Smile
It was the battery (thankfully)!
S14 Zenki Build
  Ph1 starter motor relay box? BenDturbo1 4 2,507 23-11-2013, 01:36 PM
Last Post: HDIkyle
  Starter motor; XUD/XU10 ginge191 6 4,043 19-08-2013, 09:33 PM
Last Post: Rich306
  Starter motor spinning Kilifi 9 6,040 18-07-2013, 07:58 PM
Last Post: Kilifi
