Hdi estate decat
Hdi estate decat
Bought my first mod for the hack.
Any tips for fitting it?
Cheers
extend the sockets as much as possible! I used a double depth socket, long extention, screwdriver extention & the short extention!
(15-02-2013, 05:46 PM)mad306man Wrote: Bought my first mod for the hack.
Cheers
The only advice I can give is soak the nuts and bolts on the exhaust joints with liberal doses of WD40, Duck oil, GT85 or any other penetrating oil. I would spray them up the day before you plan to take the cat out and then again when you start the job.
Cheers both
Might soak the nuts tomorrow and have a go at it on Sunday.
Will I need any gaskets?
Will I notice much of a difference with the decat? I gutted the cat on my mr2 and the difference was massive, but that's pushing a fair bit more power than the hack lol
Yeah does make a difference. Makes throttle a lot more responsive and more pull
(15-02-2013, 07:33 PM)Just Sean Wrote: Yeah does make a difference. Makes throttle a lot more responsive and more pull
I dunno if I can wait until sunday!
Didnt wait til sunday, fitted it today and what a big difference!
Cat looks original, so probs well stuffed.
Some numpty had previously fitted 2 of the round gaskets off the manifold, one on top of the other Huh
This compressed the springs so much over time that it wouldn't seal with the one gasket in.
Tried desperately to get another but no one had one. Had to botch it with a bit of exhaust paste pushed into the gasket mesh, and used washers to help compress the springs more.
So far so good, no leaks.
Gonna go for a burn in a bit to test it properly
haha! glad you enjoy it, take the cat down to the scrappers mate, should see 50quid or so!
Honestly, quite surprised by the difference. Really didn't expect much but the engine feels much more willing.
I suppose these cats only get replaced if they corrode because they are noy emission tested.
Could well be blocked as f**k for all I know
If it's an original cat, sell it. They're worth a fair bit apparently
Can be, i discovered some are only worth £60 lol. Sad
You can get new bolts and springs for the elbow-downpipe connection, only a couple of quid from your motor factors.
The bolts, springs, cup washers and gause gasket are available in a kit from the dealers, part number 179718 £13.24. I bought the kit last week and I still need to fit it.
Cheers both.
Went and got the kit today, but the ring still didn't fit!?!?
I took the original one to Peugeot and it was the same size as one from a 1.9?
Could it have an early turbo or even just an early elbow?
Confused! ?!?
Just about to test it, it better not leak
Also, I think I have found another problem, I think I have a diesel leak from the fuel tank nearest the sill Angry
Which side? Could it be coming from on top of the tank - breathers, lift pump seal, etc - or the filler elbow?
Right by the sill. Its coming off a couple of pipes between it and the tank.
It's not huge, I mean I still got 43mpg round town and caning it, which is fine right?
There is no drip drip drip etc...
It's not even enough to smell unless I get right close to it.
I'll have to monitor it as the tank goes down. I swear it was dry the other day but I could've missed it.
Does look to be coming from the top of the tank
Yeah, the sill on which side..? If it's by pipes i assume it's the off side?
Doesn't sound like it's bad, but if you can trace it now you may as well fix it before it gets worse.
Yes, offside.
Sounds a bit like this link
http://www.306gti6.com/forum/showthread.php?id=131391
Although the guys pics are dead
Im looking to do this on mine, was unsure about it until i read this thread , gonna order it up now Smile
(27-02-2013, 04:49 PM)djdommyp Wrote: Im looking to do this on mine, was unsure about it until i read this thread , gonna order it up now Smile
Its really not a bad job, and so worthwhile.
Get it done Tongue
Users browsing this thread: 21 Guest(s)
