Water leak problem
I keep having to top my coolant bottle up every 3-4 days as its emptying its self.
My drivers footwell is very soggy, iv changed the heater matrix for a brand new one and I'm still getting water in the footwell so I know it isn't the matrix. Is there any other way water could be getting into the cabin from the engine?
It's an aircon model, does the aircon run off the coolant system or is it independent??
Does the water smell of coolant once it's in the car???
(15-02-2013, 11:21 AM)Pompey306mark Wrote: Does the water smell of coolant once it's in the car???
Carnt tell cuz it's in the carpet, feels slightly greasy tho
could be the heater matrix
Iv replaced that
id say you havnt reconnected the matrix hoses properly then, if youve only just replaced the matrix itself. did you use new O rings when reconnecting the pipes?
yeh it was the orings Smile
  Water leak or Coolant Loss... Biglad 3 2,910 19-10-2016, 10:52 AM
  water leak after replacing head gasket juz22 4 3,313 17-05-2014, 09:56 AM
Last Post: juz22
  Leak of Pipe Air Leak PaddyPug 5 5,807 18-09-2013, 08:31 AM
Last Post: PaddyPug
