KKK MBC Question..
KKK MBC Question..
How does a MBC work with a KKK?
Thanks.
I think its the t2 and gt15 that share the same manifold
The kkk has a different smaller one so I don't think it will
Damn.. Would the KKK and newer K03 share the same manifold?
It'll be fine, K14 and T2 are interchangeable and share same exhaust manifold
Exhaust elbows off both turbos line up with exhaust no problem, oil lines should be the same too.
^^ill shut up then haha
Knew I'd probably be wrong
and does anyone know how a MBC works with the K14? What do you connect it to :/
Theres a little metal pipe that comes of blower housing you have to cut this halfway and then put MBC inbetween with silicone hose and zip ties well thats what i did didnt make much difference my advice would be wind the fucker right in and run big boost lol
[Image: J5hxCcC.jpg]
(16-01-2013, 02:24 PM)CJ_Derv Wrote: Theres a little metal pipe that comes of blower housing you have to cut this halfway and then put MBC inbetween with silicone hose and zip ties well thats what i did didnt make much difference my advice would be wind the fucker right in and run big boost lol
Did that on the last one mate, with a good bit of fuel and there was no impellor left in the hot side lol. You have pm by the way mate.
OK so i got a KKK "K03", but the high pressure hose isnt really lining up, it was off a 406 kkk turbo :/ dont ask...
Does the high pressure oil line off the K14's and t2's fit the K03?
