Threads: 55
17
Car Model/Spec: 406 V6
Dum-Dum Wrote:5, Sparks prove the heat there. Sparks are nearly fire.
I'd hope there was heat there, that's how the brakes work
Threads: 138
72
Car Model/Spec: Mincebus
Rippthrough Wrote:Dum-Dum Wrote:5, Sparks prove the heat there. Sparks are nearly fire.
*ahem* "I don't understand the science of it..."
I rest my case
Astor 'X' 4 GTi6- 6 - SOLD!
Threads: 171
46
Threads: 541
124
Ed Doe Wrote:Rippthrough Wrote:I'd hope there was heat there, that's how the brakes work
I rest my case
I understand that much.
brakes convert the kenetic energy of the cars movement, via friction, into heat
Threads: 55
17
Sparks are just hot iron particles from the pad/disc surface, they don't really show how much heat is in the disc, just that the disc is fairly soft or the pad fairly hard.
Threads: 138
72
Mr. Ripp. I still await your informative + rambling reply to my epic pm on '6 oc
Not sure why this is even a topic.......with 302s you cant have cyclones!! :o So clealy the '6 set up is best.
I got fade now and then in the 1.4 (266s) but maybe that was moreto do with the drums? Also got it once bad in the 1.8 (266s and rear discs) after having to slow for a speed camera, then sped up and got round a corner and had to emergency stop from 70mph........almost shat myself! Don't remeber getting it any more in the 1.8 though, so I'd imagine the '6 set up would be be fine for most driving except unusaul circumstances (like the one above).
Threads: 13
Car Model/Spec: 306 Rallye // Saab 9-3 Aero.
Ahh yess, exceptional circumstances like speeding?
Atterz Wrote:Ahh yess, exceptional circumstances like speeding?
Yeah I'm sure you never speed, plus I was young and stupid and only just got 115bhpz lol. Also, having to STOP from 70mph isn't exactly an everyday thing....especially just after slowing from 'another' high speed.
Threads: 55
17
Ed Doe Wrote:Mr. Ripp. I still await your informative + rambling reply to my epic pm on '6 oc
It was that rambling it's wandered off out of my mind entirely.
Threads: 13
I dont speed, that would be naughty.
Ducking
Threads: 138
72
I prefer Goosing myself...
Ninja-edit FTW
Threads: 27
20
I am running black diamond disks and Mintex 1155's on a 6 setup that's been completely rebuilt, any one that knows me knows how I drive and they are awsome
Threads: 24
Should have gone for Mintex discs to get the maximum out of that setup mate as they are matched friction technology.
Threads: 87
48
Brakes?? . . . . . . . . . .what are Brak . . . .ahhhhh, that's what that pedal in the middle is for then is it? . .
on a related note i run 283's and i don't have a clue what pads or discs but they stop well enough . .
Threads: 131
6
Car Model/Spec: MX5
so the 302s are from a 307? what model is it and also how hard is it to fit to a 6?
Threads: 86
there off the 2.2 16v hdi
Threads: 92
43
2.2? That wasn't in the 307, its only 2.0 and they were on the 307xsi's both perv and derv
Threads: 131
6
Car Model/Spec: MX5
ah ok so just get a new set from ECP? also what do you have to do to fit them and modifications to any thing and does it matter if abs or no abs?
All 307s are abs mate so don't worry about that.
Iirc they fit straight on once you find the right discs but I'm sure someone will confirm this!
Threads: 131
6
Car Model/Spec: MX5
just read what i wrote wasnt clear
my 306 has no abs and the 307 has abs so will they work or is there another way around it?
Threads: 138
72
^^ thought you meant that; you dont need to worry iirc; you just dont need to plug the sensors in (as there isn't anywhere to plug em in!!)
Threads: 131
6
Car Model/Spec: MX5
Well in that case
Threads: 202
58
Right! I've now decided on GTi6 283mm brakes.
So I'll ask another question :roll:
Which pad/disk combo is best?
Threads: 27
20
Iam using black diamond disks and mintex 1155's they take an age to warm up but are f*cking awesome, tad expensive but I like stopping ha ha
Threads: 13
For road use? Mintex M1144 and Brembo OE discs.
Threads: 541
124
Mintes OEM pads and discs (or if youve got money then everyone says 1144s)
Threads: 106
7
Car Model/Spec: GTi-6
Don't bother with OEM. Cooked a set on track in a few laps, the 1144's have been bulletproof!
JP
JP
