Mikalor Style Clamps
As title, where from?
I cant use paypal atm as theyve blocked my account pending verification of my address.
B and q? If not then eBay.. You can still Just pay by card instead of PayPal
bnq ... really?
Dont look very strong!
Can't see any reason why they wouldn't? Told you the leak was off the turbo Tongue
doubt b n q will have them....
My local hydrolic fitting place sells them...you maybe have something similar near by?
That said, I acaully personally hate the genuine mikalor ones, I dont like the style with bolt and built in nut, the ones with built in bolt and a nut (ebay chinease copies) work far better, and the thinner stainless band flexs to fit the pipe much better, not often id say it, but i find the cheap copies much better than the genuine ones!
[Image: sigi-2.png]
Intresting! Might get some cheap ones then. Will try ebay if i can pay via debit card
Are these cheap enough darren?
http://www.ebay.co.uk/itm/Jubilee-Worm-D...27c62f3073
Need paypal for those ones anyway! Grrr
Pretty sure those are just your normal jubilee clamps, which slip when you try to tighten them too tight... You might have to splash out a wee bit more!
Yep those are jubilee clips, for boost you want Mikalor or copies there of
Use ASH you posted in another thread, I get mine from there called T bolt clamps
TD04 11mm Sedan, now 2.1 vnt
Provence Dturbo Dead
Blaze 1.6 Dead
http://www.tom-parker.co.uk/products_sub...oups=4165B
Got these. 40 - 43mm. Should be right. Its for the turbo 90degree elbow
perfec
U need the ones with cranked bolts and thin retainer plate, or else they have to be the exact size / never work right / will drive you insane if your silicon is thicker on some than other.
[Image: sigi-2.png]
They are such a pita to size properly, bought 3 before I got one the right size because they have so little adjustment! I also used the ASH ones though...
Aslong as i can get it nice and tight it shouldnt leak anyway. The hose is 38mm diameter and the inlet on the turbo is 41mm... It might be leaking at the 90degree to c5 lower pipe end as iirc theyre both 41mm... IF 40mm is too big then its only a quid or so for the size smaller.
(14-01-2013, 01:17 PM)Toms306 Wrote: They are such a pita to size properly, bought 3 before I got one the right size because they have so little adjustment! I also used the ASH ones though...
The problem is you have to alow for silicon as well...which makes it confusing, say you have a 63mm pipe, a 63mm clamp will be a **** to get on once silicon is in situe, or at least it is if you use quality thick silicon anyway..
[Image: sigi-2.png]
Yeah I realised that after the first one....2nd one was too big though instead! Doh
  Scott Style? Eeyore 6 5,145 18-01-2013, 08:47 AM
Last Post: Tom
  In true style..... Niall 77 46,434 25-12-2012, 10:54 AM
Last Post: Connor
  Who needs Spring clamps.... HDIkyle 15 10,685 22-09-2012, 07:17 PM
Last Post: HDIkyle
