Threads: 252
7
What do people use for this? I was wanting to use a fibreglass or metal tray to mount into the bootfloor so to use aslittle space in the boot but has anyone else done this?
TD04 11mm Sedan, now 2.1 vnt
Provence Dturbo Dead
Blaze 1.6 Dead
Threads: 23
I just bent some flat bar to hold it to the boot floor in Dimma.
Threads: 55
17
Car Model/Spec: 406 V6
Great big self tapper straight through the middle, it'll be fine. Honest.
Threads: 252
7
09-01-2013, 05:19 PM
(This post was last modified: 09-01-2013, 05:22 PM by HDIkyle.)
Hmm i would prefer it enclosed tbh, Dan was that in the boot or under the car?
Anyway Phil! Where is my slightly bent bar???
Blaze 1.6 Dead
Threads: 178
28
Car Model/Spec: HDi!
I enclosed mine in a box mate...
Threads: 252
7
That's what I am doing but want it sunk tho the bootfloor. Would fibreglass be strong enuff to support a battery?
Blaze 1.6 Dead
Threads: 27
20
Iam using a sealed marine battery box can get em on eBay
81
(09-01-2013, 05:53 PM)HDIkyle Wrote: That's what I am doing but want it sunk tho the bootfloor. Would fibreglass be strong enuff to support a battery?
I would get something welded personally. Then its metal to metal. Not sure how you would wrk fibreglass to metal.
Threads: 130
82
Car Model/Spec: 106 GO-NAD
(09-01-2013, 06:33 PM)SRowell Wrote: I would get something welded personally. Then its metal to metal. Not sure how you would wrk fibreglass to metal.
with some bolts....
Threads: 252
7
Pop rivets and some sikiflex to seal it I was thinking
Blaze 1.6 Dead
Threads: 23
Just sat in the boot mate, I want to sink it in the floor, but couldn't be arsed to find a box lol
Threads: 55
17
Just bond a fibreglass box in, if you use a decent polyurethane or epoxy adhesive you'll be able to jack the car on it....
Threads: 170
cant your use a original box fromt the engine bay with the lid ant the metal bottom plate and bolt it to the boot floor?
Venetian XUD ph2 heaven
Ph3 perv cab heaven
Black ph1 XUD died
Moonstone hdi stage 2
Threads: 141
35
I've got a box welded into the bootfloor, all painted and sealed. Really looks a lot better than just having a box on the boot somewhere
Threads: 27
20
(09-01-2013, 09:31 PM)ozonehostile Wrote: I've got a box welded into the bootfloor, all painted and sealed. Really looks a lot better than just having a box on the boot somewhere
That's what Iam going to do when we corner weight it!
Threads: 252
7
Ill just use a fibreglass race box can get em for 30 on ebay and some sealant we use for bonding train windows in. Karl mine is just a metal tray I gut out as the bolts rusted didn't even hold the battery it just sat on it kinda
Blaze 1.6 Dead
Threads: 1
Car Model/Spec: ph3 Hdi 2l
Anyone got pics of it sunk in to the boot?
Threads: 141
35
not a particulerly great picture, but you get the idea
Threads: 55
17
You should have a vent on that really, otherwise the fumes can start to attack the steel if they build up when it's charging. They're particularly nice for your lungs either....
Threads: 141
35
theres no top on the battery box so i figured it would be ok. am i wrong?
Threads: 19
Car Model/Spec: Ph1 D-turbo(on going project)
should really be vented externally, would prefer top sealed and a couple holes outside underneath if it were me..
Threads: 141
35
i think i might have to do that then. just didnt want the box filling up with water
Threads: 55
17
Yeah, you want to vent the fumes outside the car really.
Threads: 27
20
Iam going to vent mine with a couple of tubes out the top into the rear sunroof drain holes, with a sealed marine box
Threads: 141
35
at least for me a vent should be easy, just need to run a tube from the box to the wheelarch or something
