Few Issues with the d-turbo..
Just got a phase 2 with a few small problems..
The speedo clock doesnt work but the rev counter does.. Sender on top of the gear box?
Heater only works on 4.. Read something about this before its a rheostat?
It grinds a little going into 4th gear only. Anyone any ideas?
Ill update later when i get the car thanks for any help lol
Sounds about right on the first two
As for the slight grind. New gearbox oil works wonders for the feel of it and noises
4WayDiablo Wrote:Sounds about right on the first two
Never thought about changing the oil im going to give it a full service anyway thanks lad!
Really does make a change to the feel of it if it hasn,t been changed for a while, if it still crunches afterwards it will be either gear box or clutch, and if its hard to get into gear then will probably be the gear linkages. Smile
On the 306 waiting list.
the hearers will be the resistor pack, its in the intake above the motor
Thanks for the help! Its a gentle grind/crunch into 4th gear so shouldn't be too bad
Going to pick this car up later, want to get the speedo sorted asap. Anyone link me to the sensor i need to buy? Its a 98 phase 2, or is there a chance i wont need one just a loose conection? Thanks
Probably best to go straight to a PUG specialist garage to buy a sensor / sender.
IIRC, To get to the sensor / sender you have to take out the driver side driveshaft anyway, I wouldn't go through that just to check it. Id buy one and if you don't need on then send it back.
As for the fourth gear grinding - sounds a syncromesh problem pal.
Syncromesh syncronises gear ratio's when you change gear - id say difficult to repair would reocmmend a new box in time
see here for info http://en.wikipedia.org/wiki/Manual_tra ... ynchromesh
Well ive had the car a couple of days now, the car grinds into 4th gear when changing gear normally. But when im changing from 3rd to 4th if i hold my foot on the clutch and let the revs drop to 1000 it will go in with no grinding.
Thanks ginge im not too worried if i need a new box ive one here for it Smile
Thats great thanks jake Smile
Syncro on 4th is worn out
