Bosch pump storage.
What is the best way to store a Bosch pump to stop it rusting inside, how do I fill it with fuel, can i use veg to store it etc?
Drop it in diesel, rotate the pulley a few times?
306ocĀ Chat Wrote:15:30: Toms306 - :Genuinely thought it was gonna explode when I was playing with Sam
Put the 'fuel in' line off your current running pump onto the spare pump, then squeeze the hand primer like 10 times and your done.
What dan said realy, fill it with grenade until it spils out the out bolt, then connect a pipe between the in / out bolts and bit of leakoff pipe with screw in the end to bung that Smile
| Dyno Power Runs & Steady StateĀ Facilities Available, Just Ask Anytime |
[Image: sigi-2.png]
  Slack in bosch pump? dt_ 14 12,186 21-10-2020, 03:41 AM
Last Post: dt_
  Bosch pump help for newbie PugRy 2 4,576 05-01-2020, 09:09 PM
Last Post: jamie182
  Bosch pump fuel screw broken Forby 0 3,174 12-03-2019, 06:47 PM
Last Post: Forby
