5.1 and 4 brake fluid
Is it ok to use 5.1 brake fluid? the cap dose say dot 4 only tho
IIRC only if you have the whole system bled through with 5.1, you cant use a mixture of them.
I usually use 5.1 when i bleed brakes on a 306.
You can use what you like, but just don't mix different dots together, 3 and 4 can mix, but anything else is a big no no
Why can't you mix them?
I was told that if it needs DOT 4, then anything DOT 4 and above would be fine....as it'll just have a higher boiling point.
Because they can react to each other... Should have been thought that at college
Connor Wrote:Because they can react to each other... Should have been thought that at college
Ah didn't know that, cheers. Smile What happens if they do react? Air bubbles I guess?
BTW, you'd be surprised what we aren't taught in college! Confusedhock:
Well its like water and oil, they don't mix... same thing for brake fluid, dot4 is a different liquid to dot5.1
Oh, fair enough. Smile
And I wouldn't be surprised at what they don't teach you, any time we had to go into the workshop at college, we always had to fix all the full time students f*ck ups...
Isnt it something to do with semi synthetic and fully synthetic or am i going nuts again?
Connor Wrote:And I wouldn't be surprised at what they don't teach you, any time we had to go into the workshop at college, we always had to fix all the full time students f*ck ups...
Lol, we spend a lot of the time fixing the school kids/level 1's muck ups (whats up with the swear filter!?).......they treat the cars there like shit tbh, wouldn't wanna let them loose near my car!!
  Best brake fluid and pads? JTaylor2005 19 11,279 19-08-2016, 08:09 PM
Last Post: Pgtips
  ATE v Pagid dot 4 brake fluid 306rhys 1 3,194 28-08-2015, 10:08 AM
Last Post: PartyJas
  Brake fluid circulation hennus 5 3,819 12-03-2015, 10:49 PM
Last Post: Niall
