Alternator
Alternator
Once again my car decides it wants to play up lol.
Changed my alternator just over a month ago as the other one was fcuked and the new one got set up fine and work fine.
But over the past week it's decided it dont want to charge the bty winkle the car is moving, only when I'm not moving or I'm coasting out of gear then it decides it wants to work.
When it works it's only charging to around 13.1 volts and I'm pretty sure it should be at 14.4 all the time........
Check all the connections are tight if you only changed it a month ago....
Got a 2 month old hdi one if it'll fit... Done under 1500 miles from brand new..
Was it an OE one or a pattern one? Mate of mine has been through 7 pattern alternators in a year, they've all been wank.
(29-12-2012, 10:43 AM)JJ0063 Wrote: Got a 2 month old hdi one if it'll fit... Done under 1500 miles from brand new..
Will it work on a DT mate?
(29-12-2012, 11:02 AM)cwspellowe Wrote: Was it an OE one or a pattern one? Mate of mine has been through 7 pattern alternators in a year, they've all been wank.
Yeah it was a valeo bud
Bump bump
No idea mate, if you want it let me know x
If you could find out aswell and if it does ill have it mate x
