Hybrid turbos
Hybrid turbos
What's the best turbo to hybrid? Has anyone done a hybrid td04 before?
I am sure Ruan will come in here....
but you may aswel have taken the countrys worth of tinned beans and opened them all....
you have effectively asked a question without entering needed information for what is needed....
Just get a VNT.
theres great advantages to hybrids...but a hybrid is built to suit an engine build....
so the question is more: why do you want a hybrid turbo?!
Well I'm running a td04 ATM but wanting something that will spall sooner but keep the power/psi as the td04
then you want a VNT
Vnt???
Variable Nozzle Turbo.
Pro's and con's
helpful info
try here
or here
more info
Expensive to buy, annoying to set up.
Pretty much spool from tickover and will power through to i dont know 5000rpm at a guess...
Im not exactly knowledgable just spouting off crap i've read on here.
Don't need vnt unless your willing to work out control etc. Go for a Garrett GT series turbo like 2056 or 52 imo.
GT2052s DTurbo
OEM+ HDI Estate
Project thread
Where?
(27-12-2012, 11:42 PM)Piggy1987 Wrote: helpful info
try here
You linky suck. Daniel son.
those can be found in saab turbos...I nearly got one...but went td04 as those quoted above arent that strong compared to the td04
(27-12-2012, 11:43 PM)Ricky Wrote: Don't need vnt unless your willing to work out control etc. Go for a Garrett GT series turbo like 2056 or 52 imo.
I've been looking at 2056 but seen they like shiting there self over 30 psi
Because they dont need to go that high, they'd be savage at 26psi.
what pump/setup have you got?!? going over 30psi will kill a vnt...as demo'd on here by another 306 dood today
Whats the power difference between the td04 that runs over 30+psi compared to the 2056 at 26psi?
(27-12-2012, 11:48 PM)Piggy1987 Wrote: what pump/setup have you got?!? going over 30psi will kill a vnt...as demo'd on here by another 306 dood today
Running a gov modded Bosch with grounded lda pin but I should be getting a 10mm soon.
again...huge question.
all depend on setup. they work differently so need different setups
Did you see my set up answer?
Piggy VNT's are completely different monsters... Ruans made 175hp? i think and that was 22psi... It a whole nother ball game.
(27-12-2012, 11:52 PM)Tom Wrote: Piggy VNT's are completely different monsters... Ruans made 175hp? i think and that was 22psi... It a whole nother ball game.
I know...thats why I said they need to be setup differently!?!?!?
(27-12-2012, 11:51 PM)David Wrote: Did you see my set up answer?
I can now...slow refresh
Ok Smile
worth working out what your target is....the goal you want to score...or the fence you want to jump....
as all the above three need different approaches...as would td04/early vnt/modern vnt
Well I'm running a td04 at 30 psi atm but want some that kicks in earlier but can hold the power
Im no expert matey...try Ruan.
I would say VNT is what would give you want you want...more expensive and complicated though.
however I wouldnt doubt a well setup 11mm pump/td04 would see good low down gains aswel as top end
(28-12-2012, 12:03 AM)Piggy1987 Wrote: Im no expert matey...try Ruan.
See I've been told the 10mm would be perfect compared to the 11mm set up. Plus I do a lot of milage.
wvo for the high mileage win!!!!
(28-12-2012, 12:00 AM)David Wrote: Well I'm running a td04 at 30 psi atm but want some that kicks in earlier but can hold the power
Garrett GT2052 or 56. spool super quick and hold boost til 5k. With a decent exhaust elbow to.
GT2052s DTurbo
OEM+ HDI Estate
Project thread
  T2 hybrid Frosty 6 4,288 08-04-2013, 12:11 PM
Last Post: Frosty
