photo/video thread, td04/t25/gt22 etc
would be a good sticky tbh, pictures and info of peoples builds and videos,ta
Most builds are in the project section
I'll upload some pics of my current turbo and my new one when I get a chance. Would be good to see how others have done it really.
Stage 2 XUD Sedan
cheers, dont get e wrong yeah there will be hundreds of cool pics and videos in peoples threads, but its a hell of a lot easier to have them all listed in one thread! Smile
This is my current setup. The turbo is turning out to be a bit of a mystery in terms of identifying exactly what it is as searching the serial number doesn't come up with any results. All I know for certain about it is that the turbo came from a MAN LE2000 rigid body lorry and is made by holset, here's a link to the website that has some good info about MAN engines and turbos for anyone that's interested in some further reading http://en.turbolader.net/turbochargers/M...arger.aspx
[Image: IMG_09311_zps981aba4d.jpg]
you gota rolling road map from that yet?!
(25-12-2012, 02:26 PM)Piggy1987 Wrote: you gota rolling road map from that yet?!
No (hangs head in shame) appointment on january 26th though Smile
What figures & graph you expecting?
[Image: sig2.png]
absolutely no idea tbh, anything over 150bhp i would be happy with considering it still on a 9mm pump without any gov mods. when its back on the road il have to take people out in it for a sort of guess the power day before the rolling road
Interesting. Hopefully your turbo will deliver most of the goods before 4/4.5k ~ then Smile
[Image: sig2.png]
(25-12-2012, 02:38 PM)Matty Wrote: Interesting. Hopefully your turbo will deliver most of the goods before 4/4.5k ~ then Smile
Ive got an 11mm, lda ground and gov modded pump waiting to go on, just want to see what its producing with a 9mm before i swap them over Smile
but yeah, luckily the turbo reaches 21psi at about 2.7k rpm so packs quite a punch without need for high revs.
Garrett GT2052 removed from a Merc 2.2 diesel. On T2 manifold, vacuum actuator replaced by modified TD04 actuator. Custom downpipe with 3" elbow with v-band connection. Will be running 18-20psi.
[Image: IMG_1114.jpg]
[Image: IMG_1133_zps5eaede62.jpg]
Car's not on the road yet because of brake problems Sad Once it's going it should be a pretty epic turbo for the B roads.
GT2052s DTurbo
OEM+ HDI Estate
Project thread
(25-12-2012, 03:14 PM)Ricky Wrote: Garrett GT2052 removed from a Merc 2.2 diesel. On T2 manifold, vacuum actuator replaced by modified TD04 actuator. Custom downpipe with 3" elbow with v-band connection. Will be running 18-20psi.
EXACTLY how it should be done on an XUD9...
Love this setup.
Is that a VNT Rickye?
Stage 2 XUD Sedan
They did both on the c220s so could be either.
[Image: sig.jpg]
(25-12-2012, 05:22 PM)strictly_derv Wrote: Is that a VNT Rickye?
Nope, sticking to wastegate to keep things simple.
Can't wait to get it on the road, it sounds epic just when revving it, so it should be even better when on boost Smile
GT2052s DTurbo
OEM+ HDI Estate
Project thread
Actually can't wait to get my 2052 fitted Big Grin
What is that inbetween the matrix hose
(25-12-2012, 07:20 PM)stevedturboxud Wrote: What is that inbetween the matrix hose
Looks like a hdi type coolant heater to me. Uses 4 glowplugs to heat the coolant.
Thats cool lol
Yeah it's a coolant heater, hasn't been wired in for a while though!
GT2052s DTurbo
OEM+ HDI Estate
Project thread
Guess that took a bit of bulkhead modification?
[Image: 20120704_212316.jpg]
[Image: IMG_1345.jpg]
[Image: IMG_1346.jpg]
[Image: DSCF2441.jpg]
Garrett GT2056S from a Vauxhall Movano 2.5D. 56mm compressor wheel, 55 trim, 0.47AR.
2.5" two-piece tight radius elbow welded to a 10mm steel adapter plate. 8" flexi section, sleeve fitting to 2.25" all the way back, looking to get a full stainless setup next year.
Absolute beast of a turbo for the application, crazy amounts of torque and nothing but wheelspin in 1st, 2nd and 3rd. 4th in the wet is pretty ropey too.
Already killed two of these in three months though so it's becoming an expensive addiction....
Something must be going wrong, surely even at 25PSI a 2052/56 would be a beast!?
Supercharged GTi6 Build
S14 Zenki Build
[Image: signature.png]
Can't figure it out mate, but thinking about it last night it must be the turbo that's popped again. First time round it was definitely user error, I hadn't clamped the compressor housing properly. This time everything was checked and double checked, turbo was solid before fitting, it was primed with oil properly, engine warmed up before pushing hard.
And it was an animal even at low RPM, the death came after the first run through the whole rev range at full throttle. f*ck knows why it popped, the gauge said about 35psi but was only for about 5 seconds, surely not enough to destroy bearings?
For the exhaust? No, just took quite a few attempts to get it angled right to clear everything!
GT2052s DTurbo
OEM+ HDI Estate
Project thread
(26-12-2012, 12:49 PM)cwspellowe Wrote: Can't figure it out mate, but thinking about it last night it must be the turbo that's popped again. First time round it was definitely user error, I hadn't clamped the compressor housing properly. This time everything was checked and double checked, turbo was solid before fitting, it was primed with oil properly, engine warmed up before pushing hard.
Does sound a bit strange, don't think I'd ever want to push more than 30PSI through the block without having rebuilt it, which you did though right? Either your the most unlucky modified XUD owner in the country or your doing something wrong! Tongue
S14 Zenki Build
Surely 35 is really high for a gt20?
GT2052s DTurbo
OEM+ HDI Estate
Project thread
Yeah it is pretty high, I didn't turn the fuel down from when I had the T2 and it was pretty maxed out, think this turbo has overboosted to the 35, before that i'd only taken it up to 25psi or so tops.
Engine was rebuilt with a new head, gasket and bolts but not properly rebuilt, cleaned up etc. Certainly not forged or anything. The T2 ran at 28psi all day long. Until it developed an interesting noise. Fuel filter was very old though so when I replaced that it started smoking more, that was after removing the T2 so probably 32+psi's worth of fuel on the T2.
T25
[Image: IMG_0573.jpg]
GT20
[Image: 26A1C385-5F9F-49CC-A73F-B337F8E00BDA-793...08005C.jpg]
Got a pic of the td04 and the GT25 down the back somewhere, but can't find them atm
  GT2052V & TD04 Oil Feed Thread silverzx 7 5,409 18-07-2014, 05:02 PM
Last Post: Tom
