clearance issue
clearance issue
Hey all i made a temp air filter pipe too day. I have used some rubber hose and all that but in the end i use intercooler pipes. It works fine but its hitting my bonnet when i shut it what i am trying too say is i wont my filter were it is but i have too have my bonnet raised so it dont hit.
i tryed useing rubber hose but it kept sucking shut can some one help me i dont want too move my filter heres some pictures of how it looks Big Grin
[Image: tempairfeed3.jpg]
[Image: tempairfeed2.jpg]
[Image: mintsig.jpg]
STAGE2 XUD DEAD ATM ENGINE REBUILD
GARRET T2-BOSCH PUMP-GROUNDED LDA PIN-GOV MOD-FMIC-STRAIT THRU STAINLESS EXHAUST SYSTEM
COMING SOON TD04 Big Grin
If you want to keep it where it is, raise the bonnet more. If not then move the filter.
On the 306 waiting list.
bonnet as bin raised lol ill get a picture of how high it is Smile
Well if it doesnt fit, then ut doesnt fit....
think i need some strong rubber hose some that wont suck shut Sad
Look how much i had too raise my bonnet so my air filter pipe dint hit but it still hits Sad
[Image: veryhighraisedbonnet2.jpg]
That looks totally retarded... but each to their own I suppose... Imo just put it back to how it was until you can sort something that allows you to shut the bonnet properly
Your bonnet appears to be broken :o ........... you should fix that!
Team Orange Engine Bay
hit the pipe with a hammer until it's flat . . . ThumbsUp
raise it more! nothing to lose
306 HDI, soon to be XUD
declantg Wrote:raise it more! nothing to lose
Apart from making it look worse and not being able to see where your going for the back of the bonnet! Confusedhock: (if you can't tell I dislike bonnet raisers lol)
I get the slight impression you hate them aha! My bonnet is raised but only buy something like 8mm Smile
Don't use rubber hose, go to a hydro place and get some reinforced almost like hoover tubing, they do some stuff that's heat resistant, Darren and I have used it before, you can make it fit past...
I really hate my bonnet bin raised Sad but i wont my filter were it is.
so i think what ruan said am gunner do thanks ruan Big Grin
Would grinded this bit of the skin under the bonnet do owr too my bonnet cos thats what my pipes are hitting ?
[Image: tempairfeed5.jpg]
As you can see by looking at the bonnet you just know its gunner hit it
What ruan said, just get decent flexi stuff...anything which has steel / hard plastic ribbing around the outside for vacume hose.....most hydro stores sell it...
[Image: sigi-2.png]
Or cut a bit of the support out of the bonnet frame?
Black 306 Rallye
Topaz Blue E39 530i Sport
Nordic Green 406 1.9TD
INXS Wrote:Or cut a bit of the support out of the bonnet frame?
You can, but then you will find it starts bending whenever you open / close the bonnet and it soon fecks the paint....
[Image: sigi-2.png]
darrenjlobb Wrote:You can, but then you will find it starts bending whenever you open / close the bonnet and it soon fecks the paint....
or you could bend the bonnet around what ever is in the way (like a massive turbo) and make it fit by forcing it closed couldn't you Darren............... lol
lol @ darrens turbo buldge Tongue
Its a speed hump..........
Obviously.... Lifting the middle of the bonnet section up everytime you come on boost due to engine movement is clearly just an "on boost engine mount"
[Image: sigi-2.png]
darrenjlobb Wrote:Obviously.... Lifting the middle of the bonnet section up everytime you come on boost due to engine movement is clearly just an "on boost engine mount"
On boost engine stabilisation FTW, I have one of those on mine, its called the bulk head lol
Pmsl! Even Ruans VNT dosnt hit the bulkhead! Clearly not enough hammer action mark! Altho ill admit its a fucker to do when the motors still in the car
[Image: sigi-2.png]
darrenjlobb Wrote:Pmsl! Even Ruans VNT dosnt hit the bulkhead! Clearly not enough hammer action mark! Altho ill admit its a fucker to do when the motors still in the car
I know, I had a bashing before I put the turbo on but its even harder when the turbo is in place as well! It will get done, it just depends if the bulkhead eats my compressor housing before I do it or not now lol either way the turbo has to come off which I just don't have the time for at the moment but the turbo rattling against the bulkhead on boost is doing my head in!
Well i sorted the clearence issue yesterday and then
my engine went boom my cam pully cracked and knocked my timing out what as bent my valves andsmashed my pistons
What a joke Stu! Sad So unlucky mate..............
I wiped my head off and checked valves and pistons and nothing seems too be broken Smile
my valves dont seem too be bent check too see if thay seal and thay do i turned them with cam bolt and not one looks bent.
Then i checked my pistons and thay seem too be working fine too so hopefully a cheap fix for me Smile
[Image: headrebuild3.jpg]
[Image: headrebuild2.jpg]
[Image: headrebuild.jpg]
She will soon be back on the road Smile
How did you check theyre sealed?
Cant believe it hit valves and didnt bend one?
  Front bumper/ intercooler clearance simonh 6 3,391 23-08-2014, 09:51 AM
Last Post: simonh
