	Threads: 33
	Threads: 36
 18
 Car Model/Spec: DT
		If you want to keep it where it is, raise the bonnet more. If not then move the filter.
On the 306 waiting list.
	Threads: 33
		bonnet as bin raised lol ill get a picture of how high it is
STAGE2 XUD DEAD ATM ENGINE REBUILD
 GARRET T2-BOSCH PUMP-GROUNDED LDA PIN-GOV MOD-FMIC-STRAIT THRU STAINLESS EXHAUST SYSTEM
 COMING SOON TD04
	Threads: 171
 46
		Well if it doesnt fit, then ut doesnt fit....
	Threads: 33
		think i need some strong rubber hose some that wont suck shut
 COMING SOON TD04
	Threads: 33
	Threads: 92
 43
		That looks totally retarded... but each to their own I suppose... Imo just put it back to how it was until you can sort something that allows you to shut the bonnet properly
	Threads: 9
 19
	Given 3 thank(s) in 1 post(s)
		Your bonnet appears to be broken  :o ........... you should fix that!
	Threads: 87
 48
		hit the pipe with a hammer until it's flat . . .
	Threads: 150
 14
 Car Model/Spec: 306 HDI
		raise it more! nothing to lose
306 HDI, soon to be XUD
	Threads: 9
 19
		declantg Wrote:raise it more! nothing to lose
Apart from making it look worse and not being able to see where your going for the back of the bonnet!    hock: (if you can't tell I dislike bonnet raisers   )
	Threads: 150
 14
		I get the slight impression you hate them aha! My bonnet is raised but only buy something like 8mm
		Don't use rubber hose, go to a hydro place and get some reinforced almost like hoover tubing, they do some stuff that's heat resistant, Darren and I have used it before, you can make it fit past...
	Threads: 33
		I really hate my bonnet bin raised    but i wont my filter were it is.
so i think what ruan said am gunner do thanks ruan
 COMING SOON TD04
	Threads: 33
		Would grinded this bit of the skin under the bonnet do owr too my bonnet cos thats what my pipes are hitting ?
As you can see by looking at the bonnet you just know its gunner hit it
 COMING SOON TD04
	Threads: 90
		What ruan said, just get decent flexi stuff...anything which has steel / hard plastic ribbing around the outside for vacume hose.....most hydro stores sell it...
	Threads: 24
 Car Model/Spec: 530i Sport/306 Rallye
		Or cut a bit of the support out of the bonnet frame?
Black 306 Rallye
Topaz Blue E39 530i Sport
Nordic Green 406 1.9TD
	Threads: 90
		INXS Wrote:Or cut a bit of the support out of the bonnet frame?
You can, but then you will find it starts bending whenever you open / close the bonnet and it soon fecks the paint....
	Threads: 9
 19
		darrenjlobb Wrote:You can, but then you will find it starts bending whenever you open / close the bonnet and it soon fecks the paint....
or you could bend the bonnet around what ever is in the way (like a massive turbo) and make it fit by forcing it closed couldn't you Darren...............
	Threads: 86
		lol @ darrens turbo buldge
	Threads: 9
 19
		Its a speed hump..........
	Threads: 90
		Obviously.... Lifting the middle of the bonnet section up everytime you come on boost due to  engine movement is clearly just an "on boost engine mount"
	Threads: 9
 19
		darrenjlobb Wrote:Obviously.... Lifting the middle of the bonnet section up everytime you come on boost due to  engine movement is clearly just an "on boost engine mount"
On boost engine stabilisation FTW, I have one of those on mine, its called the bulk head
	Threads: 90
		Pmsl! Even Ruans VNT dosnt hit the bulkhead! Clearly not enough hammer action mark! Altho ill admit its a fucker to do when the motors still in the car
	Threads: 9
 19
		darrenjlobb Wrote:Pmsl! Even Ruans VNT dosnt hit the bulkhead! Clearly not enough hammer action mark! Altho ill admit its a fucker to do when the motors still in the car
I know, I had a bashing before I put the turbo on but its even harder when the turbo is in place as well! It will get done, it just depends if the bulkhead eats my compressor housing before I do it or not now    either way the turbo has to come off which I just don't have the time for at the moment but the turbo rattling against the bulkhead on boost is doing my head in!
	Threads: 33
		Well i sorted the clearence issue yesterday and then
my engine went boom my cam pully cracked and knocked my timing out what as bent my valves andsmashed my pistons
 COMING SOON TD04
	Threads: 87
 31
		What a joke Stu!    So unlucky mate..............
	Threads: 33
	Threads: 19
 Car Model/Spec: Ph1 D-turbo(on going project)
		How did you check theyre sealed?
Cant believe it hit valves and didnt bend one?
