Threads: 581
195
When I first bought my gti, first thing I did was a cambelt. Didn't replace the waterpump as buying the car had properly cleared me out but it did need doing. So anyway, 7 months down the line and I've had a new pump, coolant and stat sitting in my room for 5 months
What I want to know is where the bloody hell do you get the tool for adjusting the tensioner? I've done 4 gti cambelts since using a home made tool but its a bit fooked now. The 1.8 was so much easier as it was just a spring loaded tensioner yo could move with a screw driver. It's basically a square hole in the tensioner, too small for a 3/8 ratchet but too big for a 1/4.
Threads: 130
82
Car Model/Spec: 106 GO-NAD
Same size as the gear box drain plug? 8mm square?
Threads: 581
195
Errr it could be actually!
Threads: 130
82
If it is, I've got one of those keys
Threads: 581
195
Lad. If so, fancy helping me do a cambelt tomorrow if the weather is any good?
Threads: 130
82
Might do. Might be doing my sisters brakes, dependant if I've fixed the nad or not really, or if I can be f*cked to go to redhill
Threads: 18
1
Car Model/Spec: Ph1 Sigma DT
Threads: 581
195
(07-12-2012, 01:10 PM)Parksy87 Wrote: Grind an 8mm allen key?
That's exactly what I did but it didn't last long
Threads: 226
24
Car Model/Spec: A3 TDi
You can buy sets of those proper drain plug sockets.. Would probably be a useful investment
Threads: 90
54
also same size as a door handle pin, which takes 2 seconds to weld to an old socket...
You can tell who the farmer is in this thread
Threads: 130
82
I tried that on the gearbox drain, kept twisting it. it was mad of cheese. soft cheese. Brie probably.
Threads: 448
51
Squeezey cheese?
Threads: 581
195
(07-12-2012, 05:11 PM)darrenjlobb Wrote: also same size as a door handle pin, which takes 2 seconds to weld to an old socket...
ah you know i never thought of that!
Threads: 90
54
(07-12-2012, 05:24 PM)samass Wrote: I tried that on the gearbox drain, kept twisting it. it was mad of cheese. soft cheese. Brie probably.
Dont buy your door handles from b&q?
Threads: 130
82
Who said I bought it?
I actually found it in the garage...
Threads: 448
51
(07-12-2012, 05:46 PM)darrenjlobb Wrote: (07-12-2012, 05:24 PM)samass Wrote: I tried that on the gearbox drain, kept twisting it. it was mad of cheese. soft cheese. Brie probably.
Hahaha amazing!!
Threads: 29
4
Figured out how an auto tensioner works?
Threads: 581
195
(07-12-2012, 08:07 PM)KrisB Wrote: Figured out how an auto tensioner works?
Yeah its easy why?
Threads: 61
4
Given 6 thank(s) in 5 post(s)
Exactly what i used but got an adjustable spanner on it.
Threads: 22
Car Model/Spec: 1998 2.0 16v XSI
I ground an M12 bolt square and welded a bar on, but i'm a tight arse..........
Threads: 16
1
Car Model/Spec: Supercharged Gti-6
I've got proper tools now I work for a pug /Citroen garage however before I've found when using an 8mm drain plug socket it gets in the way of the 13mm bolt on the tensioner. I've been known to use a mini pry bar behind it to lever the tensioner over before.
Also worth noting I've seen many a 6 engine destroyed (including my own car when I bought it) by water pump bearing failure or the veins on the back falling off and wedging up.... So get it changed  .
