Cam belt renewal
Cam belt renewal
When I first bought my gti, first thing I did was a cambelt. Didn't replace the waterpump as buying the car had properly cleared me out but it did need doing. So anyway, 7 months down the line and I've had a new pump, coolant and stat sitting in my room for 5 months lol
What I want to know is where the bloody hell do you get the tool for adjusting the tensioner? I've done 4 gti cambelts since using a home made tool but its a bit fooked now. The 1.8 was so much easier as it was just a spring loaded tensioner yo could move with a screw driver. It's basically a square hole in the tensioner, too small for a 3/8 ratchet but too big for a 1/4.
Same size as the gear box drain plug? 8mm square?
Errr it could be actually!
If it is, I've got one of those keys
Lad. If so, fancy helping me do a cambelt tomorrow if the weather is any good?
Might do. Might be doing my sisters brakes, dependant if I've fixed the nad or not really, or if I can be f*cked to go to redhill
Grind an 8mm allen key?
(07-12-2012, 01:10 PM)Parksy87 Wrote: Grind an 8mm allen key?
That's exactly what I did but it didn't last long
You can buy sets of those proper drain plug sockets.. Would probably be a useful investment Smile
also same size as a door handle pin, which takes 2 seconds to weld to an old socket...
You can tell who the farmer is in this thread Tongue
[Image: sigi-2.png]
I tried that on the gearbox drain, kept twisting it. it was mad of cheese. soft cheese. Brie probably.
Squeezey cheese?
(07-12-2012, 05:11 PM)darrenjlobb Wrote: also same size as a door handle pin, which takes 2 seconds to weld to an old socket...
ah you know i never thought of that!
(07-12-2012, 05:24 PM)samass Wrote: I tried that on the gearbox drain, kept twisting it. it was mad of cheese. soft cheese. Brie probably.
Dont buy your door handles from b&q? Wink
[Image: sigi-2.png]
Who said I bought it? Angel
I actually found it in the garage...
Hahaha amazing!!
Figured out how an auto tensioner works?
[Image: KrisB-new-Logo11.gif]
(07-12-2012, 08:07 PM)KrisB Wrote: Figured out how an auto tensioner works?
Yeah its easy why?
Exactly what i used but got an adjustable spanner on it. Smile
I ground an M12 bolt square and welded a bar on, but i'm a tight arse..........
I've got proper tools now I work for a pug /Citroen garage however before I've found when using an 8mm drain plug socket it gets in the way of the 13mm bolt on the tensioner. I've been known to use a mini pry bar behind it to lever the tensioner over before.
Also worth noting I've seen many a 6 engine destroyed (including my own car when I bought it) by water pump bearing failure or the veins on the back falling off and wedging up.... So get it changed Wink.
