27-11-2012, 09:08 AM
Are they recommended as eurocar parts don't stock Gates timing belt
Sfk timing belt
27-11-2012, 12:18 PM
They make some of the best bearings you can get also do a lot of commercial type belt products
I wouldn't have an issue fitting it
27-11-2012, 01:33 PM
i used to work for them so i have every single bearing they make for a 306 in my shed! hehe
and yes best quality stuff out there. Quote:(15:06:27) Toms306: Wd40d it and had a good tug, came straight off
27-11-2012, 03:12 PM
Need find water pump as kit don't contain one
27-11-2012, 03:34 PM
Buy a gates kit off the bay? 98delivered
27-11-2012, 03:57 PM
Best bearing you can get.
Although my Cambelt was done with the bearing and one wasnt central while rotating it would rotate at an angle and there for after a few k miles the Cambelt made a bid for freedom and shredded itself mangled some valves while it was at it :/ ![]() TEAM CONROD SHITTING RALLYE!
27-11-2012, 04:27 PM
that wasnt a skf bearing matt. all skf bearings are marked.
27-11-2012, 04:31 PM
It was. You even pointed it out to me that it was skf....
Still have it somewhere ![]() TEAM CONROD SHITTING RALLYE! |
| Timing Belt Kit | Tyronnster | 12 | 7,156 |
03-04-2013, 10:16 AM Last Post: Chris_90 |
