306 hdi unlocked ecu
After a hdi ecu unlocked for a y reg 306 with three plugs Smile
Still needed..
I have a ecu on a y reg im breaking Smile
Is it an unlocked ecu my 306 is y reg and I believe the immobiliser is stopping the car from starting also has to be a 3 plug ecu
it isnt unlocked but i can supply all the parts needed for it to work bsi chip exc can get the code off the ecu exc for you if you want Smile or if they can be unlocked via the unplug methord i can do this as its in a running car at the mo Smile
Code off the ecu? I am new to hdi only had the car 5 weeks how can u unlock the ecu?
im sure on the hdi if you swap the ecu over you need one with the same code. im no good with the derv as im a perv man myself lol but im sure someone will confirm this. as for unlocking you can send the ecu off or i know on the petrol models you can unlock it by removeing the ecu from the car with it running. i would rather supply it as a full set tho key bsi ecu exc than do this Smile
Ok ill check my numbers tonite and let you know what the are
Ok mate let me know and i will check what is on the hdi im breaking Smile
Bosch
0 281 010 592
69
Edc15c2
96 420 148 80
  Wanted Engine ECU GTI6 R Reg unlocked KevinTW 3 3,731 15-01-2020, 06:16 PM
Last Post: Mighty306
  Unlocked ECU allye 2 2,064 15-06-2016, 11:20 AM
Last Post: toseland
  Wanted - GTi6 Engine Loom and unlocked ECU Norledge 21 10,256 04-08-2013, 11:15 AM
Last Post: tbaxter08700
