Brake pipe from Peugeot
I heard a rumour a while ago that you can still buy pre-formed brake pipe for the 306? Is it true before I go in and ask?
GT2052s DTurbo
OEM+ HDI Estate
Project thread
some have been discontinued but give it a go mate. wear a helmet though so you dont hurt your head when you fall over!
(18-11-2012, 07:47 PM)Niall Wrote: wear a helmet though so you dont hurt your head when you fall over!
HAHAHAHAHAHA too true!
Stealth 3door Dturbo - In progress
http://sphotos-d.ak.fbcdn.net/hphotos-ak...6076_n.jpg
Yeah true, at the moment I only need a short amount. If I made my own do I need special unions or just ones the same size?
GT2052s DTurbo
OEM+ HDI Estate
Project thread
Make them yourself if you have the tools!!!
You need a good quality bench mounted flare tool, copper pipe and the correct unions.
Most are m10x1 male and female
I don't have the tools.
I rounded the N/S front union nut, had a look and it's really short pipe to a connection. If I do the same to the O/S then I would be pretty screwed by the looks of it..
GT2052s DTurbo
OEM+ HDI Estate
Project thread
Mole grips tbh,
[Image: wallye-gtd.JPG?raw=1]
HDi Owner for 200k/9 years
I need to buy some new mole grips, mine are ruined. Had a decent set of long nose ones but lost them Sad
GT2052s DTurbo
OEM+ HDI Estate
Project thread
I rounded a rear union but used molegrips as a removal and refitment method whilst changing the caliper. Works ok
The peugeot pre-fab pipes are available in certain locations, others you just get copper lengths appropriate for the job.
I just replaced all of mine with copper ones, only cost £30 to have someone else make them all up too.
(19-11-2012, 10:06 AM)cwspellowe Wrote: I just replaced all of mine with copper ones, only cost £30 to have someone else make them all up too.
Weren't the rears about 6ft too long? And you ended up with spaghetti under your car lol
lol on the gti yes, the estate is much neater
You don't need the proper tools! We used a large socket to form the bends for my rear brakes.. A reel of copper pipe is pretty cheap and then all you need is the right size olives and union nuts
[Image: 20120704_212316.jpg]
Don't bother buying brake pipes from Peugeot. I ordered one under the impression they were pre formed and got a straight piece of pipe. Paid £20 pounds for it as well. After the incident I still needed a pipe for the other side so got some made up for £5 pounds and self bent it. It's easy as long as you don't try to bend them at too much of a severe angle and make sure they don't catch on anything.
I tried to get some the other week and they don't sell them at all.
I was pointed into the direction of GSf/ECP/unipart and so..
  Brake pipe failure Mighty306 3 4,447 15-08-2020, 03:27 PM
Last Post: ekjdm14
  Do I buy? rear brake pipe corroded, covered in grease or other material pipes Charlie0 3 13,209 18-04-2019, 10:14 AM
Last Post: Mighty306
  Plastic brake pipe clips Mighty306 3 4,099 12-04-2018, 01:25 PM
