D turbo parts
Ph2 slam panel - £15
4x ph2 headlights - £10 per pair
3x ph2 rear lights - £10 per pair
ph2 radiator - £15
Gti-6 master cylinder - £15
Blower motor - £15
D turbo calipers - £10
D turbo interior (Red / Black one fag burn in drivers seat) - £25
not lowered drum rear axle - £30
PAS pump £20
ph3 crystal headlights £25
Decat pipe £10
original airbox and pipes £10
Freebees if you collect
ph2 front and back bumpers in silver with bump strips
interior carpet (Could do with a scrub)
Headliner
A/B/C pillars
door cards
inner arches
Loads of other parts, name what you need I'll see if I have, little things I don't mind posting for whatever it will cost.
Open to offers on parts, just not silly offers.
Fabia vRS PD130 - New daily
Astra H VXR - new toy!
engine and box by any chance?
Official Team Go-NAD fan club
(17-11-2012, 09:39 PM)the milkman Wrote: engine and box by any chance?
I have an engine and box, one of the reason's I broke the car is because I couldn't fix and nobody knew why the engine was flat.. changed injectors, injector pipes, leak-off pipes, seals and fire seals and still couldn't get to the bottom of it.
what was wrong with it exactly?
colour a/b/c pillars
(17-11-2012, 09:45 PM)the milkman Wrote: what was wrong with it exactly?
Noticed 2 of my injectors were leaking, took them out cleaned them..changed the injector seals and fire seals and cleaned the threads on the injectors and the holes. Took the car down the road and it was flat until 2900rpm where it would boost, bought refurbished injectors put them in bled it all out and still the same.
@tyronnster
all grey
no worries after black
by flat what do you mean exactly?
(17-11-2012, 09:56 PM)the milkman Wrote: by flat what do you mean exactly?
Like driving my nans mobility scooter, no wait.. my nans mobility scooter was faster
In otherwords no power at all, struggling to rev and build speed
What sort of conditon are the crystals in? Any broken clips? And is that £25 posted, or would you want postage on top?
did you not take the pump into consideration? might be fooked?
(17-11-2012, 10:07 PM)WiNgNuTz Wrote: What sort of conditon are the crystals in? Any broken clips? And is that £25 posted, or would you want postage on top?
Top clip is broken but I'm going to plastic weld it back on, other than that the lights are like new.
£25 posted
Engines sold
  Breaking: Peugeot 306 1999 T-REG Blue 1.9 TD DT D Turbo S Diesel 5 Door Breaking Parts Spares shazilla 30 22,626 23-02-2016, 03:19 AM
Last Post: Philcollins1988
  Ph2 3door black D Turbo - breaking for parts Dazecoop 18 12,595 23-12-2015, 11:44 PM
Last Post: Dazecoop
  Breaking 1.8 16 valve plus loads of d turbo and gti 6 parts wibbz 2 2,576 10-06-2014, 05:19 PM
Last Post: wibbz
