Threads: 39
1
Car Model/Spec: 306 1.6
11-11-2012, 04:34 PM
Right next thread of the day as im planning for future does anyone no if its possible to fit a 6 speed bix in a 1.6 and if so how hard and how much work would it involve as much as my 5 speed box is good i just think it needs that extra gear to get it over the top if you catch my drift.
cheers in advance craig
Threads: 226
24
Car Model/Spec: A3 TDi
I may be wrong but im pretty sure the overall ratios mean the 5 speed box has just as much top end, just the 6 gears are much closer together so the revs dont drop so much during gear changes :p
Threads: 163
53
Car Model/Spec: 406 HDI
That's right, plus the TU and XU engines have different boxes so it wouldn't fit...
Threads: 90
54
They fit on pretty easily, epic box for ragging, but no better for top end....
Threads: 39
1
Cheers for the comments the main reason for asking was for 1. Its a crusing gear ie not reving so high all the time got a straight through on it so is loud as f*ck. And 2. Is because i do plan to play with it alot which begs the question why dont i just buy a gti 6 but i like a challenge and i all ready own my 1.6 but its good to no it can be done cheers
Threads: 386
87
I also made this mistake....apparently 6th on the GTi ISN'T a cruising gear, they just move the other ratios closer together.
Threads: 581
195
(11-11-2012, 06:53 PM)Toms306 Wrote: I also made this mistake....apparently 6th on the GTi ISN'T a cruising gear, they just move the other ratios closer together.
correct. they have just moved the ratios closer...pain in town driving but is good for ragging!
Threads: 91
83
Not an easy conversion, it means pulling apart a JP4 BE3/4R and then using the bellhousing on the GTi6 casing as the starter is on the wrong side, but trust, you wouldn't want to do it on a 1.6 without adjusting the final drive, just too long...
(16-05-2016, 10:45 AM)Toms306 Wrote: Oh I don't care about the stripped threads lol, that's easily solved by hammering the bolt in.
Threads: 208
60
Given 5 thank(s) in 5 post(s)
Surly a 6 box on a 1.6 would be epicly shite?
And 6th deffently isnt a crousin gear. I hate that box on the motorway.
Threads: 31
4
Car Model/Spec: tu5 bitza/cherry dt
5th gear on a tu5 is bad enough why would you want to add a 6th?
i can only see it working if it was a tu5 jp4 or a well spec'd tu5jp
