	Threads: 448
51
		Prior to the flood damage I've occurred there was a starting issue, turn the key it will crank but won't fire up.
What could cause this? It would only start if I put my foot on the throttle
![[Image: 20A1806D-891D-40FB-BD52-AD519177A607-734...391753.jpg]](http://i35.photobucket.com/albums/d196/mattbush/20A1806D-891D-40FB-BD52-AD519177A607-7340-0000058F46391753.jpg) TEAM CONROD SHITTING RALLYE!
	Threads: 130
82
Car Model/Spec: 106 GO-NAD
		Watch out jj, hotlinking is theft....
	Threads: 130
82
		:Lol: same!
On a serious note, if you cleaned out the inlet and throttle body, and it only fire with slight throttle, might still be sticking icv, or something relating to the engine not getting any air
	Threads: 448
51
		Is there a sensor for that? By any chance is it a grey one on the side? Also occasionally I get the revs stick at 2k, so think the icv is f*cked
	Threads: 130
82
		go see poodle/niall and get it on pp man. Probably icv, get a gen. Peugeot one tho, cheap patterns tend to have short lifespans.
otherwise, the inlet air temp sensor and the manifold absolute pressure and the throttle position all tell the ecu how much air is getting into the cylinders. But I can remember which is which off hand
	Threads: 448
51
		I know there is a grey one on the tips, and a beige one on the otherside and a yellow one on the front, the grey one will be replaced as I might have set fire too it....
Also the beige one is tps, that's getting replaced tomorrow. And have no idea what the yellow one is
	Threads: 448
51
		Haha I'll get some pictures later.
The yellow one is the warmer
I know the tps
There's a small grey one on the side, which goes through to the inside, although unsure how it detects anything?
	Threads: 130
82
		if it doesnt stick out on the insidde, chances are thats your Manifold Absolute Pressure
	Threads: 448
51
		It sticks out a little, anyway I will be getting my spare throttle body and sensors tomorrow and swapping everything. Will see what happens
